API Scope.AddOp
Adds an operation to act on the inputs of the stream
HANDLE StreamH
- A handle to a previously created datascope stream
ULONG FuncOp
- An operation to perform on the input
- Typical values for this parameter:
Name Description Op_Bound Bound the current value to the expected range of the input Op_Scale Divide the current value to the expected range of the input Op_Xor Exclusive-or with the provided integer argument Op_AndNot Clear the bits in the provided integer argument Op_And Isolate only the bits in the provided integer argument Op_Orr Set the bits in the provided integer argument Op_Not Invert (ones-compliment) the current input Op_Add Add the argument to the current input Op_Sub Subtract the argument from the current input Op_Mul Multiply the argument by the current input Op_Div Divide the current input by the argument Op_Pow Raise the input to the power of the argument Op_Neg Negate (twos compliment) the current input Op_Recip Perform the reciprocal on the current input Op_Sqrt Perform a square root on the current input Op_Ln Perform a natural logarithm on the current input Op_Ln2 Perform a base-2 logarithm on the current input Op_Cos Convert the input to its cosine value (input is in radians) Op_Sin Convert the input to its sine value (input is in radians) Op_Tan Convert the input to its tangent value (input is in radians) Op_Int Convert the input from a float to an integer (using the floor function)
FLOAT Arg
- An optional argument that may be used by the FuncOp
Returns true if the operation is a success, else false
- Add to a calculation icon:
result = ::Scope.AddOp(streamh, ::Scope.Op_Bound, arg)
