API Expand.MacroName
Revision as of 17:26, 17 June 2013 by JonnyW (talk | contribs)
<sidebar>API contents</sidebar> Expands a string to the name of a macro used in the generated code
Class hierarchy
Expand
MacroName
STRING Source
The macro name to expand
HANDLE Owner
A component that owns the macro
STRING
The full expanded macro name.
This takes a macro name owned by the specified Owner component and returns the name of the macro as it would be added to the downloaded code. For example the macro TestMacro may be expanded to FCD_PARENT_OBJECT_TESTMACRO.
This should only be called during compilation if it is to match up with the generated code as compilation will calculate the static linkage of a macro at this point (a component may be redirected to some pre-existing and identical function generated by some other component in order to save space on the target).
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Expand.MacroName("source", owner)
