API File.Open
Revision as of 15:34, 10 May 2013 by Admin (talk | contribs) (XML import API auto-gen)
API contents Opens the existing file as a standard stream
STRING Filename
A textual filename to open
BOOL Read
Set to enable read access
BOOL Write
Set to enable write access
BOOL Monitor
Set to enable monitoring of the file
HANDLE
  • Add to a calculation icon: result = ::File.Open("filename", true, false, true)
