API File.NVM.WriteByte
API contents Writes a single byte to the NVM multiple times
HANDLE FileHandle
- The handle of an open file
ULONG Address
- Position in the file in bytes
BYTE Data
- Array of data to write to the file
BYTE Count
- Number of times to write the byte in sequence
- The default value for this parameter is: 1
- Declare a variable 'result' of type ULONG
- Add to a calculation icon: result = ::File.NVM.WriteByte(filehandle, address, data, count)
