Saving Images in Flowcode
Revision as of 11:11, 8 July 2013 by ReeceL (talk | contribs) (ReeceL moved page Saving a Panel Image to Saving a Flowchart Image over a redirect without leaving a redirect: revert)
<sidebar>Sidebar: Adding Finishing Touches</sidebar>
To save an image of the currently active flowchart select 'Save current Flowchart...' from the 'Save Image' sub-menu in the 'File' menu (File > Save Image > Save current Flowchart...).
This function saves an image of the program to any file in the format chosen from the list:
  • Bitmap (*.bmp)
  • JPEG (*.jpg;*.jpeg)
  • GIF (*.gif)
  • PNG (*.png)
Note that the current zoom rate is used to determine the resolution of the image saved. If you need high quality images for printing then increase the zoom rate.
From the 'Save Image' menu you also have the option to save the current image on either the 'Dashboard Panel' or the 'System Panel' (File > Save Image > Save Dashboard image... / Save System image...).
These images can be saved to any file format chosen from the list:
  • Model (*.mesh)
  • Bitmap (*.bmp)
  • GIF (*.gif)
  • PNG (*.png)
