API Panel.Position.ScaleTo
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Sets the objects scale to a value
Class hierarchy
Panel
Position
ScaleTo
HANDLE Handle
FLOAT X
The local X scale to set to
FLOAT Y
The local Y scale to set to
FLOAT Z
The local Z scale to set to
This sets the scale of the Handle object to an absolute value. Note the difference between scale and size. An objects scale is only equal to its size if it has no child objects to define its boundary.
  • Add to a calculation icon:
    ::Panel.Position.ScaleTo(handle, x, y, z)
