API Panel.LinkBar.SetEndAdjustment
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Sets the clipping adjustments for the end of the link
Class hierarchy
Panel
LinkBar
SetEndAdjustment
HANDLE LinkBar
The handle to the bar to adjust the position of
ULONG Adjustment
The automatic adjustment mode for the end position
Typical values for this parameter:
Name Description
Adjust_None The point will meet the center of the target position
Adjust_Sphere The point will meet the edge of the sphere encompassing the position
Adjust_Box The point will meet the bounding box of the sphere
FLOAT Offset
Positive to move the end point towards the center of the link
This causes the link end to clip to an offset from the center of the end position.
The Adjustment is the clipping mode for the end of the link. This is the position the link will end when considering the bounding box of the end position. The default is Adjust_Box. Adjust_Sphere will assume a spherical area around the position, and Adjust_None will end the link at the center of the position. All modes may be adjusted by Offset.
Clipping modes
The Offset is always a positive value to reduce the length of the link. That is, Offset is from the end position in the direction of the start position. Specifying 10 units will reduce the link length by 10 world units.
  • Add to a calculation icon:
    ::Panel.LinkBar.SetEndAdjustment(linkbar, ::Panel.LinkBar.Adjust_None, offset)
