API Panel.LinkBar.GetStartPos
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Gets the position the bars start point is located at
Class hierarchy
Panel
LinkBar
GetStartPos
HANDLE LinkBar
The handle to the bar to read
BOOL Track
True to get a handle to the original position, false to make a copy
HANDLE
Returns the position the bars start point is located at
The start position is specified on creation of the link or in the SetStartPos call. This will extract the latest version of this, which may not contain the same values as the original if the position is being tracked.
  • Add to a calculation icon:
    result = ::Panel.LinkBar.GetStartPos(linkbar, true)
