API Sound.Play
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Plays a formatted file sound, returns true if the sound played OK
Class hierarchy
Sound
Play
STRING Filename
The formatted file to play
BOOL
Returns true if the sound played OK
This plays WAV files given a Filename to the data. The Filename may point to a resource file. The data in the file should be in a RIFF format, see WAV file for a more detailed description of a WAV file.
  • Add to a calculation icon:
    result = ::Sound.Play("filename")
