API Expand.Property
Revision as of 14:27, 9 August 2013 by JonnyW (talk | contribs) (XML import of API documentation)
<sidebar>API Contents</sidebar> Expands a string to the name of a property used in the generated code
Class hierarchy
Expand
Property
STRING Source
The property name to expand
HANDLE Owner
A component that owns the property
BOOL AddName
Set true to return the name part of the expansion
BOOL AddValue
Set true to return the value part of the expansion
STRING
Returns the expanded name of the property
  • Declare a variable 'result' of type STRING
  • Add to a calculation icon:
    result = ::Expand.Property("source", owner, false, true)
