Saving Images in Flowcode
Revision as of 15:39, 12 August 2013 by ReeceL (talk | contribs)
<sidebar>Sidebar: Adding Finishing Touches</sidebar>
Saving a Flowchart Image
To save an image of the currently active flowchart select 'Save current Flowchart...' from the 'Save Image' sub-menu in the 'File' menu (File > Save Image > Save current Flowchart...).
This function saves an image of the program to any file in the format chosen from the list:
  • Bitmap (*.bmp)
  • JPEG (*.jpg;*.jpeg)
  • GIF (*.gif)
  • PNG (*.png)
Note that the current zoom rate is used to determine the resolution of the image saved. If you need high quality images for printing then increase the zoom rate.
Saving a Panel Image
From the 'Save Image' menu you also have the option to save the current image on either the 'Dashboard Panel' or the 'System Panel' (File > Save Image > Save Dashboard image... / Save System image...).
These images can be saved to any file format chosen from the list:
  • Model (*.mesh)
  • Bitmap (*.bmp)
  • GIF (*.gif)
  • PNG (*.png)
