Component: 4-Digit Display (Grove 104030003) (104030003) (Segment)
Jump to navigationJump to search| Author | Matrix Ltd |
| Category | Segment |
4-Digit Display (Grove 104030003) component
Quad seven segment display using an two pin communications bus to reduce the number of control pins. Based on the Grove module 104030003.
Please click here to download the component source project: FC_Comp_Source_Grove_4_Digit_Display.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Grove_4_Digit_Display.fcfx
SetLEDs
Error creating thumbnail: Unable to save thumbnail to destination
SetLEDs |
| Allows the individual LEDs for one of the segments to be set. The colon character can also be controlled when writing to digit 1. | |
Error creating thumbnail: Unable to save thumbnail to destination - BYTE
Digit |
| Which of the four digits to change. (0...3) | |
Segments |
| The binary segment control value. 0=Clear, 1=Set | |
Error creating thumbnail: Unable to save thumbnail to destination - VOID
Return |
ShowDigit
ShowDigit |
| Set the number to be displayed in the given digit of the display. The colon character can also be controlled when writing to digit 1. | |
Digit |
Value |
| The number value to set the digit to (0...15), 16=Clear | |
Colon |
| Whether to show the colon character. Digit 1 only. | |
Return |
ShowDigits
ShowDigits |
| Set the number and decimal point to be displayed in the given digit of the display. | |
Value0 |
Value1 |
Value2 |
Value3 |
Colon |
| Whether to show the colon character. | |
Return |
Properties |
Display Type |
| Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off | |
Show Seg Labels |
| Show segment name labels overlayed over the component. | |
Connections |
DIO |
| Data Pin connection to TM1637 IC | |
CLK |
| Clock Pin connection to TM1637 IC | |
Colors |
LED Color |
| Color of the LED segments when truned on. When off, they use a much darker shade of the same hue. | |
Body Color |
| Color of the plastic casing containing the LEDs. | |
Label Color |
| Color for the optional LED segment labels. | |
