Component: Air Velocity Sensor (FS3000) (Environmental)
Category Environmental
Air Velocity Sensor (FS3000) component
The FS3000 provides air velocity monitoring via a digital I2C interface.
Fc9-comp-macro.png Initialise
Sets up the I2C ready for operation and initialises the sensor with the default settings. Returns 1 if the device is correctly identified.
ReadMetersPerSecond
Fc9-comp-macro.png ReadMetersPerSecond
Reads the air flow rate and returns a floating point value in meters per second
ReadMilesPerHour
Fc9-comp-macro.png ReadMilesPerHour
Reads the air flow rate and returns a floating point value in miles per hour
ReadRaw
Fc9-comp-macro.png ReadRaw
Reads the raw output from the air velocity sensor.
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Settings
Fc9-type-16-icon.png Type
Choose which specific version of the sensor to dictate the maximum detectable air speed.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
Specifies the API component on the panel to interact with to provide comms simulation.
Please click here to download the component source project: FC_Comp_Source_Air_Velocity_FS3000.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Air_Velocity_FS3000.fcfx
