Component: Bits to Data Queue (DSP Outputs)
Version 1.2
Category DSP Outputs
Bits to Data Queue component
Allows data to be input a bit at a time from the DSP system and passed into a buffer. Useful for things like communications where data is modulated and sent out a bit at a time.
Please click here to download the component source project: FC_Comp_Source_DSP_BitsToData.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_BitsToData.fcfx
CollectNextDataBit
CollectNextDataBit
Gets the next value from the DSP buffer and attempt to add as a bit to the data queue.
CountQueueData
CountQueueData
Returns the number of data bytes received and stored in the queue.
GetByte
GetByte
Returns a byte value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
GetByteArray
GetByteArray
Returns an array of byte values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- BYTE Data
- UINT Count
GetFloat
GetFloat
Returns a float value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- FLOAT Return
GetFloatArray
GetFloatArray
Returns an array of float values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- FLOAT Data
- UINT Count
GetInt
GetInt
Returns an integer value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
GetIntArray
GetIntArray
Returns an array of integer values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- UINT Data
- UINT Count
GetLong
GetLong
Returns a long value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- ULONG Return
GetLongArray
GetLongArray
Returns an array of long values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- ULONG Data
- UINT Count
GetString
GetString
Collects a string from the receive buffer.
- UINT MaxLength
Maximum number of characters to try and receive
- STRING Return
DSP Connection Properties
Connect To
Data Queue Properties
Buffer Size
Sets the number of byte elements inside the circular buffer.
Logic Threshold
If the DSP value is >= the threshold value then a logic 1 will be stored, otherwise a logic 0 will be stored.
Tick Divider
Sometimes you will not want a new data bit every DSP tick. The Tick Divider property allow you to set how many DSP ticks to wait before writing the next bit from the data buffer.
Data Order
Selects the bit order to allow the most significant or least significant bit to be sent first.
Default State
Value used when the data queue is empty
Data Format
Decides if each byte is sent out as 8-bit, 9-bit or 10-bit packets. The 9-bit and 10-bit packet types will include a start bit that is opposite to the default state. The 10-bit packet types will also include a stop bit that is the same as the default state.
