Component: CRC (Calculation)
Category Calculation
CRC component
Proforms CRC error checking using sum or division methods.
Version information
1, 1.0, 30-09-24, MW, Component created
CRC16
Fc9-comp-macro.png CRC16
Enter databytes and data count. The checksum will be retuened as a byte
Fc9-u8-icon.png - BYTE Data
Fc9-u8-icon.png - BYTE DataLength
Actual Data length is only required if using Final XOR Value greater than 0. If not then Data length can be 0
CRC16_Array
Fc9-comp-macro.png CRC16_Array
Enter databytes and data count. The checksum will be retuened as an unsigned integer
Max data lenght (2 - 20)
CRC8
Fc9-comp-macro.png CRC8
CRC8_Array
Fc9-comp-macro.png CRC8_Array
Max data length (2 - 20)
ClearChecksumValue
Fc9-comp-macro.png ClearChecksumValue
compareChecksum
Fc9-comp-macro.png compareChecksum
Compare generated checksum uisng CRC8 or CRC16 macros. 0 = match, 1 = don't match
Fc9-u16-icon.png - UINT Checksum
Fc9-type-16-icon.png CRC Type
Fc9-type-16-icon.png CRC Size
Fc9-type-21-icon.png Poly
Fc9-type-21-icon.png Initial Value
Fc9-type-21-icon.png Final XOR Value
Please click here to download the component source project: FC_Comp_Source_CRC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CRC.fcfx
