Component: Colour Sensor (Grove 101020341) (101020341) (Light)
Version 8.0
Category Light
Colour Sensor (Grove 101020341) component
Based on the color sensor TCS34725FN with digital output I2C. Based on the 8*2 array of filtered photodiodes and 16-bits analog-to-digital converters, you can gain the color chromaticity of ambient light or the color of objects. Of the 16 photodiodes, 4 have red filters, 4 have green filters, 4 have blue filters and 4 have no filter(clear). With the synchronization input pin, external pulsed light source can provides precise synchronous conversion control.
Version information
8, 0.0, 27-06-25, MW, Not working on ESP32, changed I2C to transaction functions
CalculateLux
Fc9-comp-macro.png CalculateLux
Uses the RGB values stored in RAM from the last Sample to calculate the luminance in lux.
CalculateTemp
Fc9-comp-macro.png CalculateTemp
Uses the RGB values stored in RAM from the last Sample to calculate the colour temperature in degrees Kelvin.
ClearInterrupt
Fc9-comp-macro.png ClearInterrupt
Clears the interrupt flag allowing the device to interrupt again.
ControlInterrupt
Fc9-comp-macro.png ControlInterrupt
Enables or Disables the Interrupt pin to fire when the light levels are inside the interrupt limits.
Fc9-u8-icon.png - BYTE Enable
Range: 0 to 1 - 0=Interrupt Off / 1=Interrupt On
Fc9-u16-icon.png - UINT LowLevel
Fc9-u16-icon.png - UINT HighLevel
DisableSensor
Fc9-comp-macro.png DisableSensor
Powers down the device to save power.
EnableSensor
Fc9-comp-macro.png EnableSensor
Powers up the device ready for taking colour readings.
Fc9-comp-macro.png Initialise
Initialise the sensor configuration as set by the component properties. Sets the default intigration time and gain as well as enable the sensor.
ReadDataChannel
Fc9-comp-macro.png ReadDataChannel
Returns the value of the selected colour channel from the last sample. The Red, Green and Blue channels have a colour filter to remove light of other colours. The Clear channel has no filter allowing the ambient light level to be easily collected.
Fc9-u8-icon.png - BYTE ColourChannel
Range: 0 to 3 - 0=Red, 1=Green, 2=Blue, 3=Clear
SampleSensor
Fc9-comp-macro.png SampleSensor
Reads the raw colour channels from the sensor and stores the readings into RAM to be collected by the ReadDataChannel macro.
SetGain
Fc9-comp-macro.png SetGain
Controls the gain. 0x00 = 1X 0x01 = 4X 0x02 = 16X 0x03 = 60X
Fc9-u8-icon.png - BYTE Setting
Range: 0 to 3
SetIntegrationTime
Fc9-comp-macro.png SetIntegrationTime
Controls the integration time. 0 = 700mS / 1 = 154mS / 2 = 101mS / 3 = 50mS / 4 = 24mS / 5 = 2.4mS
Range: 0 to 5
Fc9-conn-icon.png Sensor Settings
Fc9-type-16-icon.png Integration Time
Length of time period used to sample the sensor frequency (longer is more accurate)
Fc9-type-16-icon.png Gain
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-16-icon.png Mode
Defines if the component will be used for Master or Slave communications. Master mode supports a software bitbanged I2C channel. Slave mode requires a hardware I2C peripheral to catch the communications from the Master.
Fc9-type-5-icon.png SDA
Fc9-type-16-icon.png SDA Remap Pin
Fc9-type-5-icon.png SCL
Fc9-type-16-icon.png SCL Remap Pin
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Simulation Type
Selects the simulation type for the component. Component GUI - Interacts with the panel to sense the colour of a object in close proximity to the sensor. I2C Injector - Performs the I2C commands allowing you to connect an injector component or view and debug the I2C communications.
Please click here to download the component source project: FC_Comp_Source_Colour_Sensor_I2C_Grove.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Colour_Sensor_I2C_Grove.fcfx
