| Author
Matrix Ltd
| Version
1.2
| Category
DSP Operators
Compressor component
Reduces the dynamic range of a signal by turning down levels above a threshold, with adjustable ratio, attack, release and makeup gain.
Compress
Compress
| Collects a single value from the input buffer, applies the compressor and passes the result to the output buffer.
CompressArray
CompressArray
| Passes an entire buffer through the compressor and outputs the compressed version of the buffer at the other end.
ControlCompressor
ControlCompressor
| Enables or disables the compressor, enabled by default. When disabled samples pass through unchanged.
- BOOL
State
| 0=Disable, 1=Enable
GetEnvelope
GetEnvelope
| Float and 32-bit buffer types only. Returns the detected signal level, measured from the signal centre.
- FLOAT
GetEnvelopeInt
GetEnvelopeInt
| 8/16-bit integer buffer types only. Returns the detected signal level, measured from the signal centre.
- LONG
GetGain
GetGain
| Float and 32-bit buffer types only. Returns the gain applied on the last sample, excluding makeup gain. 1.0 = no gain reduction, 0.5 = halved.
- FLOAT
GetGainQ8
GetGainQ8
| 8/16-bit integer buffer types only. Returns the gain applied on the last sample in 1/256 steps, excluding makeup gain. 256 = no gain reduction, 128 = halved.
- UINT
Reset
Reset
| Clears the envelope follower so the compressor starts again from no gain reduction.
SetAttackShift
SetAttackShift
| 8/16-bit integer buffer types only. Sets how quickly the compressor responds to a rising signal. The time constant is 2 ^ Shift samples.
- BYTE
Shift
| 0 = instant, 1 = 2 samples, 2 = 4 samples ... 15 = 32768 samples
SetAttackTime
SetAttackTime
| Float and 32-bit buffer types only. Sets how quickly the compressor responds to a signal rising above the threshold.
- FLOAT
Time_ms
| Attack time constant in milliseconds, 0 = instant
SetMakeupGain
SetMakeupGain
| Float and 32-bit buffer types only. Sets the gain applied after compression to restore the overall signal level.
- FLOAT
Multiplier
| Linear gain multiplier, 1.0 = no change
SetMakeupGainQ8
SetMakeupGainQ8
| 8/16-bit integer buffer types only. Sets the gain applied after compression in 1/256 steps, e.g. 256 = x1, 384 = x1.5, 512 = x2.
- UINT
Gain
| Makeup gain x 256, 0 to 8192 (x32)
SetRatio
SetRatio
| Float and 32-bit buffer types only. Sets the compression ratio, e.g. 4.0 for 4:1. A level 4dB above the threshold comes out 1dB above it. Large ratios act as a limiter.
- FLOAT
Ratio
| Compression ratio, 1.0 or greater. 1.0 = no compression
SetRatioShift
SetRatioShift
| 8/16-bit integer buffer types only. Sets the compression ratio as a power of two: 0 = 1:1, 1 = 2:1, 2 = 4:1, 3 = 8:1, 4 = 16:1, 5 = 32:1, 24 = limiter.
- BYTE
Shift
| Ratio = 2 ^ Shift, 0 to 5 or 24 for a limiter
SetReleaseShift
SetReleaseShift
| 8/16-bit integer buffer types only. Sets how quickly the compressor recovers once the signal falls. The time constant is 2 ^ Shift samples.
- BYTE
Shift
SetReleaseTime
SetReleaseTime
| Float and 32-bit buffer types only. Sets how quickly the compressor recovers once the signal falls.
- FLOAT
Time_ms
| Release time constant in milliseconds, 0 = instant
SetThreshold
SetThreshold
| Float and 32-bit buffer types only. Sets the level, measured from the signal centre, above which compression is applied.
- FLOAT
Level
| Threshold level in buffer units, must be greater than zero
SetThresholdInt
SetThresholdInt
| 8/16-bit integer buffer types only. Sets the level, measured from the signal centre, above which compression is applied.
- LONG
Level
| Threshold level in buffer units, 1 to 65535
Connect To
| DSP component with output buffer to collect our data from.
Buffer Size
| Number of individual elements the buffer can store, default 1.
Buffer Type
| Sets the buffer data type. Automatically matches the type of the input buffer.
Direction
| Sets the data direction flow of the component
Compressor
Processing
| Set automatically from the buffer type. 8 and 16-bit integer buffers use fixed point maths with no floating point library, ideal for 8-bit devices. 32-bit integer and float buffers use floating point maths.
Signal Centre
| Value representing a zero signal. Levels are measured as the distance from this value. Use 0 for signed buffers, or the mid point for unsigned data, e.g. 512 for a 10-bit ADC or 128 for 8-bit data.
Threshold
| Level, measured from the signal centre, above which compression starts. 1 to 65535. Uses the same units as the buffer data.
Ratio
| Amount of compression applied above the threshold. Fixed point mode works on the linear signal level: the part of the level above the threshold is divided by the ratio. Limiter holds the level at the threshold.
Attack Shift
| Attack time constant as a power of two number of samples, 0 to 15. 0 = instant, 1 = 2 samples, 2 = 4 samples, 3 = 8 samples ... Shifts are used in place of multiplies to keep the maths fast on 8-bit devices.
Attack Time (ms)
| Attack time constant resulting from the attack shift at the specified sample rate.
Release Shift
| Release time constant as a power of two number of samples, 0 to 15. 0 = instant, 1 = 2 samples, 2 = 4 samples, 3 = 8 samples ...
Release Time (ms)
| Release time constant resulting from the release shift at the specified sample rate.
Makeup Gain
| Linear gain multiplier applied after compression to restore the overall level. 1 = no change. In fixed point mode this is converted to a 1/256 step value when compiled, maximum 32.
Sample Rate (Hz)
| Rate at which samples are passed through the compressor. Used to convert between attack and release times and samples.
Please click here to download the component source project: FC_Comp_Source_DSP_Compressor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Compressor.fcfx
