Component: DAC (MCP48x1) (MCP48x1) (Analog Output)
| Category | Analog Output |
DAC (MCP48x1) component
Component to drive a digital to analogue converter (DAC) IC from Microchip via an SPI interface. Compatible with MCP4801 (8-Bit), MCP4811 (10-Bit) and MCP4821 (12-Bit) devices.
Please click here to download the component source project: FC_Comp_Source_DAC_MCP48x1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DAC_MCP48x1.fcfx
ControlPins
Disable
|   | Disable |
| Disables the DAC output. | |
|  - VOID | Return |
Enable
|   | Enable |
| Enables the DAC Output. | |
|  - VOID | Return |
|   | Initialise |
| Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated. | |
|  - VOID | Return |
SetOutput
|   | SetOutput |
| Sets the output voltage of the DAC 8-Bit: Range 0-255 10-Bit: Range 0-1023 12-Bit: Range 0-4095 | |
|  - UINT | DAC_Value |
| The value to output to the DAC | |
|  - VOID | Return |
