Component: DALI Slave (Comms: System)
Jump to navigationJump to search| Author | MatrixTSL |
| Category | Comms: System |
DALI Slave component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND using external circuitry.
Please click here to download the component source project: FC_Comp_Source_DALI_Slave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DALI_Slave.fcfx
An example that shows how to use the Dali Slave to receive packets then take actions accordingly
CheckForGroupAddress
|   | CheckForGroupAddress |
| Tests the 16-bit incoming data for the defined group address Returns 0 for no match, returns 1 for a match | |
|  - UINT | Data |
|  - BYTE | Return |
CheckForIndividualAddress
|   | CheckForIndividualAddress |
| Tests the 16-bit incoming data for the defined individual address Returns 0 for no match, returns 1 for a match | |
|  - UINT | Data |
|  - BYTE | Return |
CollectDataByte
|   | CollectDataByte |
| Returns the data byte from a 16-bit data packet | |
|  - UINT | Data |
|  - BYTE | Return |
CollectPacketType
|   | CollectPacketType |
| Returns if the incoming packet was data or a command. Return of 0 = Data Return of 1 = Command | |
|  - UINT | Data |
|  - BYTE | Return |
|   | Initialise |
| Configures the UART serial interface. | |
|  - VOID | Return |
ReceiveForwardFrame
|   | ReceiveForwardFrame |
| Attempts to receive an 16-bit command from the master controller. 0xFFFF indicates timeout or no reply | |
|  - UINT | Return |
TransmitBackwardFrame
|   | TransmitBackwardFrame |
| Send out a 8-bit frame consisting of a data byte. | |
|  - BYTE | Data |
| Data Byte | |
|  - BYTE | Return |
|   | Properties |
|   | Serial Properties |
|   | TX Pin |
|   | RX Pin |
|   | DALI Slave Properties |
|   | Individual Address |
| Address ranging from 0-63 | |
|   | Group Address |
| Address ranging from 0-15 | |
|   | Simulation |
|   | API |
