Component: DC Motor (Half Bridge) ()
Author Matrix Ltd.
Version 1.1
Category
DC Motor (Half Bridge) component
DC Motor that can be driven in a single direction using digital output pin.
Please click here to download the component source project: FC_Comp_Source_Motor_simple.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Motor_simple.fcfx
Simple example showing how to drive the motor components and how to create sub assemblies attached to the motor output shafts in the simulation panels. Motors
Start
Start
Set the motor running by turning on its pin.
Stop
Stop
Turn off power to the motor by turning off its pin.
Pin
Active State
Motor Settings
Direction
Speed
Speed of the motor when turned on.
Acceleration
Speed change per second when the motor us powered. Set to zero for instantaneous speed changes.
Deceleration
Speed change per second when the motor is coasting with no power. Set to zero for instantaneous speed changes.
Show Actuator
When activated, an actuator will appear so that the animation can be seen more easily.
Linkage
Target Object
An object or group to link the motor to - the object will move along with the motor.
