Component: DDS DAC Synth (AD9851) (Analog Output)
Category Analog Output
DDS DAC Synth (AD9851) component
Digitally programmable frequency synthesiser module.
Fc9-comp-macro.png Initialise
Sets up the pin connections to the module, ready for communications
Reset
Fc9-comp-macro.png Reset
Resets the DDS module
SweepTone
Fc9-comp-macro.png SweepTone
This function will generate Frequency Sweep signal
Fc9-u32-icon.png - ULONG Frequency
Center frequency in Hz
Fc9-u32-icon.png - ULONG Deviation
Sweep deviation in Hz
Fc9-s32-icon.png - LONG Step
Step or Frequency Resolution in Hz + or -
Fc9-u16-icon.png - UINT Delay_us
Time in micro seconds between each step
WriteFrequency
Fc9-comp-macro.png WriteFrequency
This function will write the desired frequency into AD9851 and generate SINE WAVE The 6 x Clock multiplier is always enabled (assume that you are using 30 MHz clock) Frequency range: DC - 90 MHz (DC - 60 MHz in practice)
Fc9-type-5-icon.png Reset
Fc9-type-5-icon.png Data
Fc9-type-5-icon.png FQ_UD
Fc9-type-5-icon.png CLK
Please click here to download the component source project: FC_Comp_Source_AD9851_DDS_DAC_Frequency_Synth.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AD9851_DDS_DAC_Frequency_Synth.fcfx
