| Category | Runtime Tools |
Event Log component
A simulation component designed to create a simple log record of events in your SCADA system. Logs to a file and / or to a console tab including optional automated time stamp.
Please click here to download the component source project: FC_Comp_Source_EventLog.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EventLog.fcfx
LogEvent
|   | LogEvent |
| Allows an event string to be logged |
|  - STRING | LogString |
|  - VOID | Return |
|   | Properties |
|   | Log To Console |
|   | Log To File |
|   | Include Timestamp |
| Controls if a timestamp is appended to the start of the log string. Yes: Add timestamp to log string No: Leave log string as is |
|   | Console Properties |
|   | Console Name |
|   | Clear On Init |
| Selects if the contents of the console are maintained or wiped on runtime start. Yes: Console is automatically cleared No: Console is maintained and appended |
|   | File Properties |
|   | Log File |
| File to store the log data.  Default: $(srcdir)log.txt  $(srcdir) specifies the directory containing your Flowcode project file. log.txt specifies a file named log.txt  If the file does not exist then it will be automatically created for you. |
|   | Clear On Init |
| Selects if the contents of the log file are maintained or wiped on runtime start. Yes: Log file is automatically cleared No: Log file is maintained and appended |
|   | Timestamp Properties |
|   | TimeStamp |
|   | US Date Format |
| Specifies the format of the date string.  No - "DD/MM/YY"  Yes - "MM/DD/YY" |
