Component: Type Conversions Free (Calculation)
Category Calculation
Type Conversions Free component
Component to simplify the task of converting data into different bit type variables. Allows conversion between Bytes, Ints, Longs and Floats. Useful when you need to store Ints, Longs and Floats into Byte based memory. Uses a simple 32-bit C Union to overlay the following variable types into the same RAM space. Byte[4], Int[2], Long, Float
Please click here to download the component source project: FC_Comp_Source_TypeConversionsFree.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TypeConversionsFree.fcfx
The type conversion component is aimed at allowing for simple, relible and efficient ways of converting between 8-bit, 16-bit and 32-bit values.
The component consists of a single 32-bit block of memory that consists of the following data types which are all overlaid on each other.
4 x 8-bit Bytes
2 x 16-bit INTs
1 x 32-bit Long
1 x 32-bit Float
  • MSB = Most significant bit
  • LSB = Least significant bit
For communications systems you may need to send or receive data as bytes.
So to pack up a float into bytes you would load a floating point value and then collect the 4 bytes.
To repack the floating point value at the other end you would load the 4 bytes and then collect the floating point value.
Here is a simple project showing how to convert between bytes, ints, longs and floats.
FC6 Icon.png Type Conversions Exmple
GetByte
Fc9-comp-macro.png GetByte
Gets a single 8-bit BYTE value. Index is in little endian, 0 is the LSB and 3 is the MSB
Fc9-u8-icon.png - BYTE Index
Range: 0-3
GetFloat
Fc9-comp-macro.png GetFloat
Gets a single 32-bit FLOAT value
GetInt
Fc9-comp-macro.png GetInt
Gets a single 16-bit INT value Index is in little endian, 0 is the LSW and 1 is the MSW
Range: 0-1
GetLong
Fc9-comp-macro.png GetLong
Gets a single 32-bit LONG value
Fc9-u32-icon.png - ULONG Return
SetByte
Fc9-comp-macro.png SetByte
Sets a single 8-bit BYTE value Index is in little endian, 0 is the LSB and 3 is the MSB
Range: 0-3
Fc9-u8-icon.png - BYTE Value
Range: 0-255
SetFloat
Fc9-comp-macro.png SetFloat
Sets a single 32-bit FLOAT value
Range: 0-4294967295
SetInt
Fc9-comp-macro.png SetInt
Sets a single 16-bit INT value. Index is in little endian, 0 is the LSW and 1 is the MSW
Range: 0-1
Fc9-u16-icon.png - UINT Value
Range: 0-65535
SetLong
Fc9-comp-macro.png SetLong
Sets a single 32-bit LONG value
Fc9-u32-icon.png - ULONG Value
Range: 0-4294967295
Fc9-type-7-icon.png Generate Code
