Component: Zigbee (EB051, XBEE) (XBEE) (Wireless)
(Redirected from Component: ID 53548cbe cd57 471c 8ac1 3205d0e9da38)
Jump to navigationJump to search| Author | Matrix Ltd. |
| Version | 1.5 |
| Category | Wireless |
- 1 Zigbee (EB051, XBEE) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 ConnectFromLibrary
- 5.2 ConnectToAddress
- 5.3 ConnectToAll
- 5.4 ConnectToCoordinator
- 5.5 ConnectToName
- 5.6 EnterCommandMode
- 5.7 ExitCommandMode
- 5.8 GetATResponse
- 5.9 GetSignalLevel
- 5.10 InitNetwork
- 5.11 MIAC_Module_GetData
- 5.12 MIAC_Module_Message
- 5.13 MIAC_Module_PushData
- 5.14 NodeConfigureSleep
- 5.15 NodeWake
- 5.16 ReadATResponse
- 5.17 ReadAddressFromBuffer
- 5.18 ReadNameFromBuffer
- 5.19 ReceiveChar
- 5.20 RestartNetwork
- 5.21 ScanBuffer
- 5.22 ScanNetwork
- 5.23 SendATCommand
- 5.24 SendChar
- 5.25 StoreParams
- 6 Property reference
Zigbee component designed to work with the XBEE range of modules from Digi. Provides a very simple interface to allow Zigbee mesh networks and communications. Also available in the form of the EB051 Zigbee E-block. Can also be used with Zigbee MIAC Addon module
Please click here to download the component source project: FC_Comp_Source_Zigbee.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Zigbee.fcfx
ConnectFromLibrary
| ConnectFromLibrary | |
| Attempts to connect the data channel to a known device on the network. | |
| Mode | |
| Device | |
ConnectToAddress
| ConnectToAddress | |
| Attempts to connect the data channel to a specific device address on the network. | |
| Address | |
ConnectToAll
| ConnectToAll | |
| Attempts to connect the data channel to all devices on the network. | |
| ConnectToCoordinator | |
| Attempts to connect the data channel to the network coordinator node. | |
ConnectToName
| ConnectToName | |
| Attempts to connect the data channel to a named device on the network. | |
| Name | |
EnterCommandMode
| EnterCommandMode | |
| Moves from data mode into command mode by sending the special characters | |
ExitCommandMode
| ExitCommandMode | |
| Returns from command mode to allow data to be sent and received | |
GetATResponse
| GetATResponse | |
| Waits for a response from the Zigbee module. If the Logging parameter is set then the response is stored in memory allowing the software to read the reply. | |
| Logging | |
GetSignalLevel
| GetSignalLevel | |
| Returns the signal strength of the last signal received | |
InitNetwork
| InitNetwork | |
| Initialises the Zigbee module and attempts to setup or join the network | |
MIAC_Module_GetData
| MIAC_Module_GetData | |
| Index | |
MIAC_Module_Message
| MIAC_Module_Message | |
| CAN_ID | |
| CMD_ID | |
| MIAC_Module_PushData | |
| Data | |
NodeConfigureSleep
NodeWake
| NodeWake | |
| Wakes up the local Zigbee module from sleep mode. | |
ReadATResponse
| ReadATResponse | |
| Reads a single byte from the received AT command response. | |
| idx | |
| Specified the byte index in the buffer. Range 0-15 | |
| ReadAddressFromBuffer | |
| Reads a byte from a 16-bit Zigbee device address | |
| Device | |
| Idx | |
ReadNameFromBuffer
| ReadNameFromBuffer | |
| Returns a byte from the 8-Byte name | |
| Device | |
| The Device name to collect. Range: 0-7 | |
| Idx | |
| The index position of the name. Range: 0-7 | |
ReceiveChar
| ReceiveChar | |
| Attempt to receive a byte from the Zigbee module. | |
| nTimeout | |
RestartNetwork
| RestartNetwork | |
| Attempts to restart the network | |
ScanBuffer
| ScanBuffer | |
| Returns a binary list of matched identifier names | |
| Compare_Str | |
| Length | |
ScanNetwork
SendATCommand
| SendATCommand | |
| Transmits a string of values to the Zigbee module. | |
| Command | |
| Transmits a command to the Zigbee module followed by a carriage return | |
SendChar
| SendChar | |
| Transmits a byte value to the Zigbee module. | |
| Byte | |
| Data byte to transmit. Range 0-255 | |
StoreParams
| StoreParams | |
| Stores the current register set into the Zigbee module's non volatile memory | |
