Component: Switch Extension ()
Author | |
Version | 1.0 |
Category |
Switch Extension component
An extension to the default switch Overlays the switch with a mesh
Please click here to download the component source project: FC_Comp_Source_Switch_ext.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_ext.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
Properties |
