Component: E-Blocks 3 (USB Comms) (E-blocks 3)
Version 3.0
Category E-blocks 3
E-Blocks 3 (USB Comms) component
Low level routines for connecting the E-blocks 3 hardware to the computer using a USB COM port serial data connection.
ChangeHWBaud
Fc9-comp-macro.png ChangeHWBaud
Changes the hardware UART baud rate allowing for dynamic speed changes.
Fc9-u8-icon.png - BYTE NewBaud
0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200, 8=250000
Fc9-comp-macro.png Initialise
Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
ReceiveBinary16Bit
Fc9-comp-macro.png ReceiveBinary16Bit
Receives a binary 16-bit value split across two bytes.
Fc9-bool-icon.png - BOOL MSBfirst
0=Least significant byte first, 1=Most significant byte first
Fc9-u8-icon.png - BYTE Timeout
Max amount of time in ms to wait between bytes
ReceiveBinary32Bit
Fc9-comp-macro.png ReceiveBinary32Bit
Receives a binary 32-bit value split across four bytes.
Fc9-u32-icon.png - ULONG Return
ReceiveBinaryFloat
Fc9-comp-macro.png ReceiveBinaryFloat
Receives a binary 32-bit floating point value split across four bytes.
ReceiveByteArray
Fc9-comp-macro.png ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
Fc9-u8-icon.png - BYTE Data
Array to store the incoming data
Fc9-u16-icon.png - UINT NumBytes
Maximum number of bytes to try and receive
ReceiveChar
Fc9-comp-macro.png ReceiveChar
Attempts to receive a single packet from the UART interface.
Time to wait in milliseconds for valid data before returning, 0=Dont wait, 255=Wait forever.
Fc9-s16-icon.png - INT Return
ReceiveFloat
Fc9-comp-macro.png ReceiveFloat
Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
Max time in ms to wait in between bytes
Fc9-bool-icon.png - BOOL IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
ReceiveHexNumber
Fc9-comp-macro.png ReceiveHexNumber
Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
Fc9-bool-icon.png - BOOL Prefix
Look for prefix before receiving, 1=0xFF, 0=FF
ReceiveINTArray
Fc9-comp-macro.png ReceiveINTArray
Receives an array of 16-bit INT/UINT values and returns the number of values received.
Fc9-u16-icon.png - UINT Data
Fc9-u16-icon.png - UINT NumValues
Maximum number of values to try and receive
ReceiveNumber
Fc9-comp-macro.png ReceiveNumber
Attempts to receive a number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
ReceiveString
Fc9-comp-macro.png ReceiveString
Attempts to receive a string of bytes from the UART interface.
The number of bytes to try and receive, ideally your string variable should have at least 1 more byte to store the null termination byte
SendBinary16Bit
Fc9-comp-macro.png SendBinary16Bit
Sends out a 16-bit binary value split across two bytes.
Fc9-u16-icon.png - UINT Value
SendBinary32Bit
Fc9-comp-macro.png SendBinary32Bit
Sends out a 32-bit binary value split across four bytes.
Fc9-u32-icon.png - ULONG Value
SendBinaryFloat
Fc9-comp-macro.png SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
SendByteArray
Fc9-comp-macro.png SendByteArray
Transmits an array of bytes via the UART peripheral
Data to transmit
Number of bytes to send from the array
SendChar
Fc9-comp-macro.png SendChar
Sends out a single packet from the UART interface.
Fc9-s16-icon.png - INT Char
SendFloat
Fc9-comp-macro.png SendFloat
Sends out a floating point number as an ASCII String from the UART interface.
Fc9-f32-icon.png - FLOAT Number
SendHexNumber
Fc9-comp-macro.png SendHexNumber
Sends out a number as an ASCII hexadecimal String from the UART interface.
Fc9-u32-icon.png - ULONG Number
Fc9-u8-icon.png - BYTE NumChars
Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SendINTArray
Fc9-comp-macro.png SendINTArray
Transmits an array of 16-bit INT/UINT values via the UART peripheral
Data to transmit
Number of 16-bit values to send from the array
SendNumber
Fc9-comp-macro.png SendNumber
Sends out a number as an ASCII String from the UART interface.
Fc9-s32-icon.png - LONG Number
SendString
Fc9-comp-macro.png SendString
Sends out a string of bytes from the UART interface.
Fc9-conn-icon.png Comms Settings
Fc9-type-16-icon.png Channel
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Textual label shown on the component I/O flasher
Fc9-type-16-icon.png Console Format
Controls if the data is shown as a log with time and date stamps or just as raw data
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
Please click here to download the component source project: FC_Comp_Source_EB3_USB_COM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EB3_USB_COM.fcfx
