Component: Switch Rotary 0 - 15 (Switch)
Version 1.1
Category Switch
Switch Rotary 0 - 15 component
Version information
GetPosition
GetPosition
Reads the position of the switch as a number between 0 and NumPositions-1
SetPosition
SetPosition
Sets the switch position
- BYTE Position
The new state of the switch (true=on, false=off)
Type
Choose output connection type: - Encoded (Binary Coded Decimal / Hex) - Conventional (non-encoded direct connections)
Num Positions
The number of positions available on the switch (between 2 and 16)
Pin 1
Pin connection / bit 0 of encoded value
Pin 2
Pin connection / bit 1 of encoded value
Pin 3
Pin connection / bit 2 of encoded value
Pin 4
Pin connection / bit 3 of encoded value
Common
The common pin connection
Component Label
Customise the text label or use the component name
Show Position Numbers
Show or hide the numbers around the switch
Style
Visual style for the switch
Pointer
The type of pointer to display
Please click here to download the component source project: FC_Comp_Source_Switch_Rotary_0_-_15_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Rotary_0_-_15_2dgi.fcfx
