| Author | Matrix Ltd |
| Version | 1.2 |
| Category | Sensors |
Collision Detector Template component
Polls a chosen panel object to see if it has collided with another object. When collisions happen, a user notification event is generated and a pin is set or reset.  Another event is sent when the two objects separate.
Please click here to download the component source project: FC_Comp_Source_Collision_Detector.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Collision_Detector.fcfx
ReadState
|   | ReadState |
| Get the current collision state. The 'Polarity' property will affect whether a collision is represented by a high or low state. |
|  - BYTE | Return |
SetTarget
|   | SetTarget |
| Set the object that you want to test for collision with. If this is not called, or is called with handle = 0, collisions will be tested against every panel object that has 'Solid' status. NB) Specifying an object will save CPU power!! |
|  - HANDLE | Target |
| The object to test for collision with. |
|  - VOID | Return |
WaitUntilHigh
|   | WaitUntilHigh |
| Pause the program until the detector goes high.  'Polarity' will affect whether high value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!! |
|  - VOID | Return |
WaitUntilLow
|   | WaitUntilLow |
| Pause the program until the detector goes low.  'Polarity' will affect whether low value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!! |
|  - VOID | Return |
|   | Properties |
|   | Connections |
|   | Pin |
| The pin that should change state when objects collide or separate. |
|   | Polarity |
| Active High = Pin is high when objects collide, low when they are separate. Active Low = Pin is low when objects collide, high when they are separate. |
|   | Simulation |
|   | Test Object |
| The object to test for collisions. A user event is sent each time this object collides with any other, or when the two object separate. |
|   | Mouse Object |
| Choose an object that the user can clock on to simulate a collision when testing. |
|   | Detector Ident |
| An ID value to identify this particular detector.  Will be sent as the 'Ident' value for the notification events sent out so that multiple detectors can be told apart. |
|   | Timer Interval (ms) |
| Time in milliseconds between collision scans. Small time = Greater CPU load Large time = More like to miss brief collisions. |
