Component: J1939 (Misc)
Author
Version 1.1
Category Misc
J1939 component
Please click here to download the component source project: FC_Comp_Source_J1939.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_J1939.fcfx
Get_Address
Fc9-comp-macro.png Get_Address
Returns the device (ECU) actual address
Get_Status
Fc9-comp-macro.png Get_Status
Returns the system status. 0 = Ready. 1 = Waiting address claim
Fc9-comp-macro.png Initialise
Initialise the CAN network and J1939 protocol
Fc9-u8-icon.png - BYTE Preferred_Address
Preferred Address (Requested Address)
Message_Data_Clear
Fc9-comp-macro.png Message_Data_Clear
Clear the CAN Data Buffer
Fc9-u8-icon.png - BYTE DataBuffer
Message_Data_Read_SPN
Fc9-comp-macro.png Message_Data_Read_SPN
Read the SPN value from the CAN data buffer
Fc9-u16-icon.png - UINT SPN
Message_Data_Set
Fc9-comp-macro.png Message_Data_Set
Set all data in CAN Data Buffer to given value. e.g. 0 or 0xFF
Fc9-u8-icon.png - BYTE Value
Message_Data_Write_SPN
Fc9-comp-macro.png Message_Data_Write_SPN
Write the SPN value to the CAN data buffer
Fc9-u16-icon.png - UINT Value
Process
Fc9-comp-macro.png Process
Does the message processing. Call this often.
Fc9-u16-icon.png - UINT TimeElapsed
Time elapsed since last call, in mS. Can be zero for frequent calling.
Rx_Message_Check
Fc9-comp-macro.png Rx_Message_Check
If a data message has been received returns the PGN,otherwise 0
Rx_Message_Data
Fc9-comp-macro.png Rx_Message_Data
Returns the DLC and data of the last received message
Rx_Message_Source
Fc9-comp-macro.png Rx_Message_Source
Returns the Source Address of the last received message
Rx_Transfer_Check
Fc9-comp-macro.png Rx_Transfer_Check
Check for incoming multipart data transfers. If received, returns the PGN else 0
Fc9-u32-icon.png - ULONG Return
Rx_Transfer_Data
Fc9-comp-macro.png Rx_Transfer_Data
Returns the byte count and data of the transfer message data
Buffer to receive copied data
Fc9-u16-icon.png - UINT Size
Size (byte count) of buffer
Tx_Message_Send
Fc9-comp-macro.png Tx_Message_Send
Send the prepared CAN message
Fc9-u16-icon.png - UINT PGN
Fc9-u8-icon.png - BYTE DLC
Tx_Transfer_Send
Fc9-comp-macro.png Tx_Transfer_Send
Send a mulitpart data transfer message. Returns number of bytes accepted. Limited by max message size.
Fc9-u32-icon.png - ULONG PGN
Multipart message program number
Data buffer to send
Number of data bytes to send
Fc9-conn-icon.png NAME
Fc9-type-16-icon.png Industry Group
Fc9-type-16-icon.png Vehicle System Instance
Fc9-type-21-icon.png Vehicle System
Fc9-type-21-icon.png Function
Fc9-type-21-icon.png Function Instance
Fc9-type-16-icon.png ECU Instance
Fc9-type-21-icon.png Manufacturer Code
Fc9-type-21-icon.png Identity Number
Fc9-type-21-icon.png Transmit Message Buffer Size
Byte buffer size to allocate for transmitted multipart messages. Maximum is 1785 or available RAM
Fc9-type-21-icon.png Receive Message Buffer Size
Byte buffer size to allocate for received multipart messages. Maximum is 1785 or available RAM
Fc9-conn-icon.png CAN
Fc9-type-16-icon.png Channel
Switches between Internal CAN peripheral and External CAN controller IC MCP2515.
Fc9-type-16-icon.png Controller Osc
Fc9-type-16-icon.png Bus Rate
Data rate of the bus specified in thousand bits per second, Kbps.
Fc9-conn-icon.png SPI
Fc9-type-16-icon.png CHANNEL
SPI Channel selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png SS
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-16-icon.png Sample Point
Data bit read sample point
Fc9-type-16-icon.png Config Delay
