Component: JSON Encoder (Comms: IoT/Cloud)
| Category | Comms: IoT/Cloud |
JSON Encoder component
Allows dynamic key and value pairs to be created and assembled into a formatted JSON string.
Please click here to download the component source project: FC_Comp_Source_JSONEncoder.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_JSONEncoder.fcfx
Simple Data
Example program showing how to use a JSON encoder component to create a simple JSON encoded data string.
Simple Encode and Decode
Example program showing how to take data and encode it into a JSON string to be sent out over comms.
The example also hows how to decode a received JSON string and pull out values.
AssignDataAsFloat
|   | AssignDataAsFloat |
| Assigns a data value as a floating point value | |
|  - UINT | Element |
| Index of the element to assign the data to | |
|  - FLOAT | Data |
|  - BYTE | NumDP |
| Number of decimal points | |
|  - VOID | Return |
AssignDataAsNumber
|   | AssignDataAsNumber |
| Assigns a data value as a integer value | |
|  - UINT | Element |
|  - LONG | Data |
|  - VOID | Return |
AssignDataAsString
|   | AssignDataAsString |
| Assigns a data value as a string | |
|  - UINT | Element |
|  - STRING | Data |
|  - VOID | Return |
AssignName
|   | AssignName |
| Assigns a name value as a string. Call this macro first before assigning data to the element. | |
|  - UINT | Element |
|  - STRING | Name |
|  - VOID | Return |
ClearAll
|   | ClearAll |
| Clears all the names and data values out of the buffer | |
|  - VOID | Return |
GenerateJSON
|   | GenerateJSON |
| Generates a JSON data string with the current specified values. | |
|  - STRING | Return |
