Component: Neuron (Calculation)
Version 1.3
Category Calculation
Neuron component
Performs a single-neuron calculation of Z = W · X + B. Sums weight * input for each input, adds bias, then optionally applies an activation function (Linear, ReLU, Sigmoid, Tanh or Leaky ReLU). Use SetWeights / SetWeight and SetBias to configure, set inputs with SetInput or pass an array to Calculate / CalculateSingle. Use CalculateLoss or CalculateLossFromResult to measure error against a target value.
Calculate
Calculate
Calculates Z = sum(Weight[i] * Input[i]) + Bias, then applies the selected activation. Returns the activated output and also stores it in Result.
- FLOAT InputArray
Array of input values (one per input)
- FLOAT Return
CalculateLoss
CalculateLoss
Calculates loss between a predicted value and a target value using the Loss Type property. MSE = (Predicted - Target)^2. MAE = abs(Predicted - Target). Binary Cross Entropy = -(Target * log(Predicted) + (1 - Target) * log(1 - Predicted)). Stores the value in Loss and returns it.
- FLOAT Predicted
Predicted / output value
- FLOAT Target
Expected / target value
- FLOAT Return
CalculateSingle
CalculateSingle
Convenience for a single-input neuron: Z = Weight[0] * X + Bias, then activation. Uses only input index 0. Ideal when Number of Inputs is 1.
- FLOAT X
Single input value
- FLOAT Return
CalculateStored
CalculateStored
Same as Calculate, but uses the inputs previously stored with SetInput. Useful when filling inputs one at a time.
- FLOAT Return
Clears all weights, inputs, bias, result and loss to 0.0.
SetBias
SetBias
Sets the bias offset constant B used in Z = W · X + B.
- FLOAT Value
Bias value
SetInput
SetInput
Stores a single input value for later use by CalculateStored. Index range: 0 to (Number of Inputs - 1).
- BYTE Index
Input index (0 based)
- FLOAT Value
Input value to store
SetWeight
SetWeight
Sets a single weight value by index. Index range: 0 to (Number of Inputs - 1).
- BYTE Index
Weight index (0 based)
- FLOAT Value
Weight value to store
SetWeights
SetWeights
Copies an array of weight values into the neuron. The array must contain at least Number of Inputs elements.
- FLOAT WeightArray
Array of weight values (one per input)
Number of Inputs
Number of inputs (and weights) used by the neuron. Range: 1 to 32.
Activation
Activation applied after Z = W · X + B. Linear returns Z unchanged. ReLU returns max(0, Z). Sigmoid returns 1 / (1 + exp(-Z)). Tanh returns (2 / (1 + exp(-2Z))) - 1. Leaky ReLU returns Z when Z > 0, otherwise Leak Slope * Z.
Loss Type
Error / loss function used by CalculateLoss and CalculateLossFromResult. MSE = (Predicted - Target)^2. MAE = abs(Predicted - Target). Binary Cross Entropy is intended for Sigmoid outputs in the range 0 to 1.
Please click here to download the component source project: FC_Comp_Source_Neuron.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Neuron.fcfx
