Component: OBD2 ECU (Server) (Misc)
Author
Category Misc
OBD2 ECU (Server) component
Implements an ECU side OBD-II server
Please click here to download the component source project: FC_Comp_Source_OBD2_ECU.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_OBD2_ECU.fcfx
DTC_Add
Fc9-comp-macro.png DTC_Add
Adds a DTC to the store (e.g. "B1318") Checks to see if the DTC string is already in the store before adding.
Fc9-string-icon.png - STRING DTC_String
Fc9-bool-icon.png - BOOL CheckExists
Checks to see if error code already exists
DTC_Clear
Fc9-comp-macro.png DTC_Clear
Clears the DTC store
DTC_Count
Fc9-comp-macro.png DTC_Count
Returns the number of stored DTCs
DTC_Get
Fc9-comp-macro.png DTC_Get
Get the DTC from the store at Index
Fc9-u16-icon.png - UINT Index
FlushBuffer
Fc9-comp-macro.png FlushBuffer
Clears the contents of the buffer and re-initialises the index locations.
GetByte
Fc9-comp-macro.png GetByte
Reads the next available byte from the circular buffer, Returns 255 if the buffer is empty.
GetNumberBytes
Fc9-comp-macro.png GetNumberBytes
Returns the number of valid data bytes currently inside the buffer.
Fc9-comp-macro.png Initialise
Initialise the CAN network
Process
Fc9-comp-macro.png Process
Does the message processing. Call this often.
Fc9-u16-icon.png - UINT TimeElapsed
Time elapsed since last call, in mS. Can be zero for frequent calling.
Set_ECU_Name
Fc9-comp-macro.png Set_ECU_Name
Set the ECU Name
Fc9-string-icon.png - STRING Name
Set_Engine_Coolant_Temperature
Fc9-comp-macro.png Set_Engine_Coolant_Temperature
-40 to 215 (deg C)
Value range -40 to 215 deg C
Set_Engine_Load
Fc9-comp-macro.png Set_Engine_Load
0 to 100 (%)
Speed in RPM
Set_Engine_Speed
Fc9-comp-macro.png Set_Engine_Speed
0 to 16,383.75 (rpm)
Speed in RPM
Set_MAF_Rate
Fc9-comp-macro.png Set_MAF_Rate
0 to 655.35 grams/sec
MAF air flow rate in grams/sec
Set_Throttle_Position
Fc9-comp-macro.png Set_Throttle_Position
0 - 100 (%)
Position value as a percentage (0 - 100%)
Set_VIN
Fc9-comp-macro.png Set_VIN
Set the 17 character VIN
Fc9-string-icon.png - STRING VIN
Set_Vehicle_Speed
Fc9-comp-macro.png Set_Vehicle_Speed
0 - 255 (km/h)
Speed in RPM
Fc9-type-21-icon.png DTC Store Size
Maximum number of DTC codes to store
Fc9-type-10-icon.png VIN
17 character Vehicle Identification Number
Fc9-conn-icon.png CAN
Fc9-type-16-icon.png Channel
Switches between Internal CAN peripheral and External CAN controller IC MCP2515.
Fc9-type-16-icon.png Controller Osc
Fc9-type-16-icon.png Bus Rate
Data rate of the bus specified in thousand bits per second, Kbps.
Fc9-conn-icon.png SPI
Fc9-type-16-icon.png CHANNEL
SPI Channel selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png SS
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-16-icon.png Sample Point
Data bit read sample point
Fc9-type-16-icon.png Config Delay
