Component: Output (DSP)
| Author | Matrix Ltd |
| Version | 1.2 (Release) |
| Category | DSP |
Allows the values from a buffer to be read. Either a value at a time or as an array.
Here is a basic example demonstrating how to pass a value from the DSP chain.
Delay
The output value in the example goes to a PWM component but this can be passed to anything such as stored into a CSV file on a SD card or passed to an external I2C device etc.
ReadRawTick
Returns the value from the specified buffer at the current index position as is without any type casting or scaling.
ReadAsByteTick
Returns the value from the specified buffer at the current index position as a byte. If the buffer has a higher bit depth then the return value will be appropriately scaled.
ReadAsUINTTick
Returns the value from the specified buffer at the current index position as a unsigned int. If the buffer has a lower bit depth then the return value will be appropriately scaled.
ReadAsSINTTick
Returns the value from the specified buffer at the current index position as a signed int. If the buffer has a lower bit depth then the return value will be appropriately scaled.
- INT Data
Simulation macro reference
ReadFromBuffer
Returns an array of values from the specified buffer at the current index position as a byte array. If the buffer has a higher bit depth then the return value will be appropriately scaled.
- <- STRING Data
Buffer Manager
This property is of type Fixed list of ints and can be referenced with the variable name buffer_manager.
Reference to DSP system buffer manager component.
Output
This property is of type Fixed list of ints and can be referenced with the variable name input_a.
Buffer assigned to output channel
