Component: RMT (Internal) (Misc)
Version 2.0
Category Misc
RMT (Internal) component
Provides access to the onboard remote control (RMT) peripheral allowing for high speed data input / output without requiring bit banging from the ESP32 processor.
Initialises the RMT module ready for data to be sent or received.
SetBuffer
SetBuffer
Writes data to the RMT buffer
- UINT Index
Array index, Range: 0 - (BufferSize - 1)
- BOOL State0
The first state to output
- UINT Length0
The length of the first output state in divided clock periods
- BOOL State1
The second state to output
- UINT Length1
The length of the second output state in divided clock periods
Transmit
Transmit
Sends out the RMT data buffer.
- BYTE WaitWhileComplete
0=Dont Wait, 1=Wait for TX to complete
TransmitBusy
TransmitBusy
Checks to see if the RMT channel is currently transmitting. Returns 1 if transmitting and 0 if transmission is complete.
- INT Timeout
Timeout delay in ms, 0 for no delay, -1 for wait forever
Mode
Controls if we are transmitting or receiving data
Pin
Pin to assign the RMT functionality
Clock Divider
Base Clock speed is 80MHz. Div by 1 = 80MHz Div by 2 = 40MHz Div by 4 = 20MHz Div by 8 = 10MHz
Mem Block Num
Starting RMT memory block
Buffer Size
Number of values inside the data buffer, 64 = 1 Block A buffer size of 128 would consume two sequential blocks of memory. If starting at block 1 then you can have a maximum buffer size of 512 consuming all 8 blocks.
Tx Properties
TX Loop Enable
Allows the transmit buffer to be constantly looped.
TX Carrier Enable
Enables a carrier frequency to be overlaid on the transmitted data
TX Idle Output
When not transmitting should the Transmit pin be an active output?
TX Idle Level
Sets the output state when idle.
Please click here to download the component source project: FC_Comp_Source_RMT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RMT.fcfx
