Component: Switch Array (Slide) (Switches)
Author MatrixTSL
Version 13.13
Category Switches
Switch Array (Slide) component
An array of up to eight slide switches. In embedded mode each switch is connected to a single pin of the specified port.
Version information
9, 9.0, 25-06-24, MW, Added option to customise appearance of individual or all switches
10, 10.0, 26-06-24, MW, Corrected switch and component name bug
12, 11.0, 16-04-25, MW, Corrected bug when sim stopped Switch changed from on to off, but pin remained at VCC
12, 11.0, 16-04-25, MW, Added properties of Ev_PropertiesEX to Ev_Initialise
12, 11.0, 16-04-25, MW, Fixed bug so individual customisation now works
 12, 11.0, 16-04-25, MW, Created a new component icon
13, 13.0, 25-09-25, MW, updated to brig in-line with Switch Array Push
Here is an example Flowcode program to read the values of a switch array. FC6 Icon.png Switch Array
(5V / 11K) * 10K = 4.54545V
ReadAll
Fc9-comp-macro.png ReadAll
Reads all of the switches at once, returning a byte containing one bit per switch.
ReadState
Fc9-comp-macro.png ReadState
Read the state of the switch at the given index.
Fc9-u8-icon.png - BYTE Index
The switch to read the status of.
WaitUntilHigh
Fc9-comp-macro.png WaitUntilHigh
Pause the program until the switch at the given index is turned on.
Index of the switch to wait for.
WaitUntilLow
Fc9-comp-macro.png WaitUntilLow
Fc9-type-16-icon.png Count
The number of LEDs in the array from 1 to 8.
Fc9-conn-icon.png Function
Fc9-type-7-icon.png Simulation Only
Fc9-conn-icon.png Switch Settings
Fc9-type-16-icon.png Input Mode
Choose a single port for all LEDs - pins are allocated in sequence from pin 0 - 7 ...or choose 'Custom pins' to assign each switch individually.
Fc9-type-19-icon.png Port
Fc9-type-16-icon.png Polarity
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF
Fc9-type-14-icon.png Debounce
Time in milliseconds allowed for the pin to settle following a change of state.
Fc9-type-16-icon.png Operation
Sets whether switches toggle or are press/release. NB) This option can only be set when the original target includes this option.
Fc9-conn-icon.png Appearance
Allows you to add your own label to each switch. If Same as Handle is selected then all custom text will be erased.
Fc9-type-16-icon.png Switch layout
Fc9-type-21-icon.png Distance between switches
Set distance betwwn each switch. Default = 55
Fc9-type-16-icon.png Style
Fc9-type-16-icon.png Type
Fc9-type-10-icon.png On Label
Fc9-type-10-icon.png Off Label
Fc9-type-1-icon.png Label Colour
Fc9-type-7-icon.png Show Connection Label
Fc9-type-7-icon.png Show Pin Value
Please click here to download the component source project: FC_Comp_Source_Switch_Array_Slide_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Array_Slide_2dgi.fcfx
