Component: TCP/IP (EB023 v1) (E-blocks 1)
Version 2.0
Category E-blocks 1
TCP/IP component
TCP/IP component designed to work with the WIZ3100 range of modules from Wiznet. Also available in the form of the version 1 EB023 E-block which uses the NM7010A module.
Please click here to download the component source project: FC_Comp_Source_TCPIP_EB023-00-1_EB.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_EB023-00-1_EB.fcfx
CreateIPSocket
CreateIPSocket
Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels.
- BYTE Channel
Specifies the communications channel 0-3
- BYTE Protocol
Specifies which IP protocol to use
- BYTE Broadcast
Allows broadcast type packets to be sent and received
CreateIPSocket_Sim
CreateIPSocket_Sim
- BYTE Channel
- BYTE Protocol
- BYTE Broadcast
CreateMACSocket
CreateMACSocket
This macro creates a socket for sending and receiving Ethernet data using raw data.
- BYTE Promiscuous
Receive everything (1) or just data bound for your MAC (0)
- BYTE Broadcast
Allows broadcast messages to be accepted (1) or rejected (0)
- BYTE Error
Allowsmessages with errors to be accepted (1) or rejected (0)
CreateMACSocket_Sim
CreateMACSocket_Sim
- BYTE Promiscuous
- BYTE Broadcast
- BYTE Error
CreateTCPSocket
CreateTCPSocket
This macro creates a socket for sending and receiving TCP data.
- BYTE Channel
- BYTE Src_Port_Hi
Port High Byte
- BYTE Src_Port_Lo
Port Low Byte
CreateTCPSocket_Sim
CreateTCPSocket_Sim
- BYTE Channel
- BYTE Src_Port_Hi
Port High Byte
- BYTE Src_Port_Lo
Port Low Byte
CreateUDPSocket
CreateUDPSocket
This macro creates a socket for sending and receiving UDP data.
- BYTE Channel
- BYTE Src_Port_Hi
Port High Byte
- BYTE Src_Port_Lo
Port Low Byte
CreateUDPSocket_Sim
CreateUDPSocket_Sim
- BYTE Channel
- BYTE Src_Port_Hi
Port High Byte
- BYTE Src_Port_Lo
Port Low Byte
GetSocketStatus
GetSocketStatus
This returns the state of the requested channel's socket.
- BYTE Channel
GetSocketStatus_Sim
GetSocketStatus_Sim
- BYTE Channel
InitialiseSim
InitialiseSim
RxDataAvailable
RxDataAvailable
This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available.
- BYTE Channel
RxDataAvailable_Sim
RxDataAvailable_Sim
- BYTE Channel
RxDataSize
RxDataSize
This macro is used to detect the size of data collected by the Rx_data_available macro.
- BYTE Channel
RxDataSize_Sim
RxDataSize_Sim
- BYTE Channel
RxFlushData
RxFlushData
Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
- BYTE Channel
RxFlushData_Sim
RxFlushData_Sim
- BYTE Channel
RxMatchMyIP
RxMatchMyIP
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
- BYTE Channel
RxMatchMyIP_Sim
RxMatchMyIP_Sim
- BYTE Channel
RxMatchMyMAC
RxMatchMyMAC
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
- BYTE Channel
RxMatchMyMAC_Sim
RxMatchMyMAC_Sim
- BYTE Channel
RxMatch_2_Bytes
RxMatch_2_Bytes
This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
- BYTE Channel
- BYTE Byte1
Specifies the value of the first byte
- BYTE Byte2
Specifies the value of the second byte
RxMatch_2_Bytes_Sim
RxMatch_2_Bytes_Sim
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
RxMatch_4_Bytes
RxMatch_4_Bytes
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
- BYTE Byte3
Specifies the value of the third byte
- BYTE Byte4
Specifies the value of the fourth byte
RxMatch_4_Bytes_Sim
RxMatch_4_Bytes_Sim
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
- BYTE Byte3
- BYTE Byte4
RxMatch_6_Bytes
RxMatch_6_Bytes
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
- BYTE Byte3
- BYTE Byte4
- BYTE Byte5
Specifies the value of the fifth byte
- BYTE Byte6
Specifies the value of the sixth byte
RxMatch_6_Bytes_Sim
RxMatch_6_Bytes_Sim
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
- BYTE Byte3
- BYTE Byte4
- BYTE Byte5
- BYTE Byte6
RxReadByte
RxReadByte
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE Channel
RxReadByte_Sim
RxReadByte_Sim
- BYTE Channel
RxReadHeader
RxReadHeader
Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
- BYTE Channel
- BYTE Idx
Specifies the byte index to return
RxReadHeader_Sim
RxReadHeader_Sim
- BYTE Channel
- BYTE Idx
RxReadString
RxReadString
A call to this macro will return a string of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE Channel
- BYTE Length
- STRING Return
RxReadString_Sim
RxReadString_Sim
- BYTE Channel
- BYTE Length
- STRING Return
RxSkipBytes
RxSkipBytes
Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
- BYTE Channel
- BYTE Count
Specifies how many bytes to skip
RxSkipBytes_Sim
RxSkipBytes_Sim
- BYTE Channel
- BYTE Count
SetDestination
SetDestination
This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes.
- BYTE Channel
- BYTE Dst_IP0
Specifies the first byte of an IP address
- BYTE Dst_IP1
Specifies the second byte of an IP address
- BYTE Dst_IP2
Specifies the third byte of an IP address
- BYTE Dst_IP3
Specifies the fourth byte of an IP address
- BYTE Dst_Port_Hi
Port High Byte
- BYTE Dst_Port_Lo
Port Low Byte
SetDestination_Sim
SetDestination_Sim
- BYTE Channel
- BYTE Dst_IP0
- BYTE Dst_IP1
- BYTE Dst_IP2
- BYTE Dst_IP3
- BYTE Dst_Port_Hi
Port High Byte
- BYTE Dst_Port_Lo
Port Low Byte
SetMyIP
SetMyIP
This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
- BYTE IP0
First Byte of IP address
- BYTE IP1
Second Byte of IP address
- BYTE IP2
Third Byte of IP address
- BYTE IP3
Fourth Byte of IP address
TCPClose
TCPClose
When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
- BYTE Channel
TCPClose_Sim
TCPClose_Sim
- BYTE Channel
TCPConnect
TCPConnect
This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
- BYTE Channel
- BYTE Dst_IP0
- BYTE Dst_IP1
- BYTE Dst_IP2
- BYTE Dst_IP3
- BYTE Dst_Port_Hi
High Byte of destination port
- BYTE Dst_Port_Lo
Low Byte of destination port
TCPConnect_Sim
TCPConnect_Sim
- BYTE Channel
- BYTE Dst_IP0
- BYTE Dst_IP1
- BYTE Dst_IP2
- BYTE Dst_IP3
- BYTE Dst_Port_Hi
- BYTE Dst_Port_Lo
TCPListen
TCPListen
This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
- BYTE Channel
TCPListen_Sim
TCPListen_Sim
- BYTE Channel
TxEnd
TxEnd
Once the transmit buffer has been filled with data, call this macro to actually send the data.
- BYTE Channel
TxEnd_Sim
TxEnd_Sim
- BYTE Channel
TxSendByte
TxSendByte
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information.
- BYTE Channel
- BYTE Data
Data byte to append to Tx buffer.
TxSendByte_Sim
TxSendByte_Sim
- BYTE Channel
- BYTE Data
TxSendMyIP
TxSendMyIP
This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
- BYTE Channel
TxSendMyIP_Sim
TxSendMyIP_Sim
- BYTE Channel
TxSendMyMAC
TxSendMyMAC
This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
- BYTE Channel
TxSendMyMAC_Sim
TxSendMyMAC_Sim
- BYTE Channel
TxSendString
TxSendString
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a string of information.
- BYTE Channel
- STRING Data
- BYTE Length
TxSendString_Sim
TxSendString_Sim
- BYTE Channel
- STRING Data
- BYTE Length
TxStart
TxStart
This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
- BYTE Channel
TxStart_Sim
TxStart_Sim
- BYTE Channel
Max Channels
I2C Address
Network Interface
SIM IP
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Int Pin
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP1
IP2
IP3
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
