Component: WLAN (EB069-00-2, RN171) (RN171) (Wireless)
Jump to navigationJump to search| Author | Matrix Ltd. |
| Version | 1.1 |
| Category | Wireless |
WLAN (EB069-00-2, RN171) component
Wireless LAN component designed to work with the RN171 module from Microchip. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the EB069-00-2 E-block.
Please click here to download the component source project: FC_Comp_Source_WLAN-RN171_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN-RN171_Dummy.fcfx
Simple playback example - allows a wav file to be streamed out using PWM. Repeats the playback in a loop.
Simple recording example - allows a wav file to be recorded from a microphone connected to an ADC input pin. Records for approx 10 seconds.
CheckForPageRequests
|   | CheckForPageRequests |
| To be called periodically. Returns non-zero if a request has been processed | |
|  - BYTE | Return |
ConnectToSSID
|   | ConnectToSSID |
| Attempts to connect to the given SSID and Key values. Returns 0 if successful. | |
|  - STRING | SSID |
|  - STRING | Key |
|  - BYTE | Return |
DisableCommandMode
|   | DisableCommandMode |
| Exits command mode | |
|  - VOID | Return |
EnterCommandMode
|   | EnterCommandMode |
| Attempts to leave data mode and enter command mode | |
|  - VOID | Return |
GetInValue
|   | GetInValue |
| Returns the string value of a Request parameter | |
|  - BYTE | index |
| Index of the request paramter, starting at zero. | |
|  - STRING | Return |
GetReply
|   | GetReply |
| Returns the last received response to a command. 0 = OK 1 = FAIL_ERR 2 = STX_ERR 3 = CMD_ERR 4 = PARAM_ERR 5 = ETX_ERR 6 = SERIAL 255 = TOUT | |
|  - BYTE | Return |
|   | Initialise |
| Initialise the device with the property data. Returns 0 if successful | |
|  - BYTE | Return |
ReadConnectionStatus
|   | ReadConnectionStatus |
| Checks the connection status. Returns 0 if not connected, 1 if connected. | |
|  - BYTE | Return |
ReceiveIncoming
|   | ReceiveIncoming |
| Returns the received data string | |
|  - STRING | Return |
SendCommand
|   | SendCommand |
| Sends the given command and returns the reply status. (See GetReply for return values) | |
|  - STRING | Command |
|  - BYTE | Return |
SendString
|   | SendString |
| Sends the given Text. Appends a CR/LF pair of characters it CrLf is true. | |
|  - STRING | Text |
|  - BYTE | CrLf |
|  - VOID | Return |
SetOutValue
|   | SetOutValue |
| Set the value of an outbound substitution string | |
|  - BYTE | index |
|  - STRING | value |
|  - VOID | Return |
|   | Properties |
