Component: Humidity AHT10 (Environmental)
Category Environmental
Humidity AHT10 component
A high precision I2C based temperature and humidity sensor.
Please click here to download the component source project: FC_Comp_Source_Humidity_AHT10.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Humidity_AHT10.fcfx
Fc9-comp-macro.png Initialise
Startup I2C bus and initialise the sensor. Returns 1 if the device is replying to commands.
ReadHumidity
Fc9-comp-macro.png ReadHumidity
Gets the humidity reading from the last sample.
ReadTemperature
Fc9-comp-macro.png ReadTemperature
Gets the temperature reading from the last sample.
Sample
Fc9-comp-macro.png Sample
Reads the sensor and collects the latest termperature and humidity readings. Returns 1 for a successful sample.
Fc9-conn-icon.png I2C Options
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-16-icon.png SDA Remap Pin
Fc9-type-5-icon.png SCL
Fc9-type-16-icon.png SCL Remap Pin
Baud rate to be used
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
Specifies the API component on the panel to interact with to provide comms simulation.
