Component: DFPlayer (MP3 / WAV) (Audio Output)
Category Audio Output
DFPlayer (MP3 / WAV) component
A small module capable of streaming MP3 and WAV audio files from a micro SD card. Controlled via a serial UART connection to the microcontroller.
Please click here to download the component source project: FC_Comp_Source_DFPlayer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DFPlayer.fcfx
No Examples here yet
GetError
Fc9-comp-macro.png GetError
Checks for any errors and returns the error code. 1=ModuleBusy, 2=SleepMode, 3=SerialError, 4=ChecksumError, 5=TrackOutOfScope, 6=TrackNotFound, 7=InsertionError, 8=SDFail, 10=Sleep
GetReplyByte
Fc9-comp-macro.png GetReplyByte
Reads a single byte from the last reply. Each reply contains 4 bytes starting with the command code.
Fc9-u8-icon.png - BYTE Index
Range: 0-3 / 0=Command, 1=Feedback, 2=Data MSB, 3=Data LSB
Fc9-comp-macro.png Initialise
Sets up the UART and does some housekeeping. Must be called before calling any of the other component macros.
IsPlaying
Fc9-comp-macro.png IsPlaying
Checks to see if the last played track is still playing
IsReplyAvailable
Fc9-comp-macro.png IsReplyAvailable
Checks to see if new data has been received from the module. Returns true when new data is available. Collect the data using the GetReplyByte macro.
PausePlayResetStop
Fc9-comp-macro.png PausePlayResetStop
Allows the current playing track to be paused, restarted or reset
Fc9-u16-icon.png - UINT Mode
0=Pause, 1=Play, 2=Reset, 3=Stop
PlayTrack
Fc9-comp-macro.png PlayTrack
Plays track from the selected folder. MP3 & Advert folder track numbers should be 4 characters long e.g. 0001 any name.mp3, Other folder track numbers should be 3 characters long e.g. 001 Any name.mp3, Root the Track played in placement order.
Fc9-u8-icon.png - BYTE Directory
0=Root, 1=Folder "01" - 99=Folder "99", 100=MP3, 101=Advert
Fc9-u16-icon.png - UINT Track
Track number 1="001*.MP3" / "0001*.MP3", 100="100*.MP3" / "0100*.MP3"
SendCommand
Fc9-comp-macro.png SendCommand
Sends a command to the DFPlayer module
Fc9-u8-icon.png - BYTE Command
Command code byte
Fc9-bool-icon.png - BOOL Feedback
Collect feedback byte: Range 0-1
Fc9-u16-icon.png - UINT Parameter
16-bit Parameter
SetEQ
Fc9-comp-macro.png SetEQ
Sets the equaliser mode for the module
Fc9-u8-icon.png - BYTE EQMode
Range: 0-5 0=Normal, 1=Pop, 2=Rock, 3=Jazz, 4=Classic, 5=Bass
SetVolume
Fc9-comp-macro.png SetVolume
Sets the volume level for the module
Fc9-u8-icon.png - BYTE Volume
Range: 0 (min) - 30 (max)
SkipTrack
Fc9-comp-macro.png SkipTrack
Jump to the next or previous track
Fc9-bool-icon.png - BOOL Direction
0=Next, 1=Previous
WhilePlaying
Fc9-comp-macro.png WhilePlaying
Blocking function that waits for module to stop being busy. Returns true if the module is still busy and the timeout period has passed.
Fc9-u16-icon.png - UINT Timeout
Number of milliseconds to wait, 0=WaitForever
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-7-icon.png Use Busy Pin
Controls if we are monitoring the busy pin or not. Used by the IfBusy component macro.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Console Format
Controls if the data is shown as a log with time and date stamps or just as raw data
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
Fc9-type-16-icon.png API
Selects which API component to route the communication data via. Add API components to the panel before they will be available in this list. API components are available from the Comms component category.
