Component: RGB LED SK6812 RGBW (LEDs)
Version 1.5
Category LEDs
RGB LED SK6812 RGBW component
A simple chained RGBW LED controller IC allowing multiple LEDs to be controlled using a serial data stream. Compatible with the SK6812 RGBW Type Controller ICs. Allows RGBW LEDs to be driven with full 24-bit colour depth plus 8-bit white channel. Allows single chains, 2D arrays and 3D cube formations to be simulated. Requires a high speed microcontroller to generate the critical timings to drive the device.
Please click here to download the component source project: FC_Comp_Source_LED_SK6812RGBW.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_SK6812RGBW.fcfx
LED Resistor Calculator Tool
Delay_T0H
Fc9-comp-macro.png Delay_T0H
Delay_T0L
Fc9-comp-macro.png Delay_T0L
Delay_T1H
Fc9-comp-macro.png Delay_T1H
Delay_T1L
Fc9-comp-macro.png Delay_T1L
DrawCuboid3D
Fc9-comp-macro.png DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
Fc9-u8-icon.png - BYTE X1
Start X pixel coordinate
Fc9-u8-icon.png - BYTE Y1
Start Y pixel coordinate
Fc9-u8-icon.png - BYTE Z1
Start Z pixel coordinate
Fc9-u8-icon.png - BYTE X2
End X pixel coordinate
Fc9-u8-icon.png - BYTE Y2
End Y pixel coordinate
Fc9-u8-icon.png - BYTE Z2
End Z pixel coordinate
Fc9-u8-icon.png - BYTE DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
Fc9-u8-icon.png - BYTE R
Red Colour Channel
Fc9-u8-icon.png - BYTE G
Green Colour Channel
Fc9-u8-icon.png - BYTE B
White Colour Channel
Fc9-u8-icon.png - BYTE W
DrawLine2D
Fc9-comp-macro.png DrawLine2D
Draws a line on a 2D array of LEDs
Fc9-u16-icon.png - UINT X1
Start X Coordinate
Fc9-u16-icon.png - UINT Y1
Start Y Coordinate
Fc9-u16-icon.png - UINT X2
End X Coordinate
Fc9-u16-icon.png - UINT Y2
End Y Coordinate
Red colour channel
Green colour channel
Blue colour channel
White colour channel
DrawLine3D
Fc9-comp-macro.png DrawLine3D
Draws a line on a 3D array of LEDs
Start X Coordinate
Start Y Coordinate
Fc9-u16-icon.png - UINT Z1
Start Z Coordinate
End X Coordinate
End Y Coordinate
Fc9-u16-icon.png - UINT Z2
End Z Coordinate
Red Colour Channel
Blue Colour Channel
DrawRectangle2D
Fc9-comp-macro.png DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
GetLEDColour
Fc9-comp-macro.png GetLEDColour
Sets the colour of a single LED in RAM as a 1D array.
Fc9-u16-icon.png - UINT LED
LED to change the colour / Range: 0 to (LED Count - 1)
Fc9-u8-icon.png - BYTE ColIdx
0 = Red, 1 = Green, 2 = Blue, 3 = White
GetLEDIndex2D
Fc9-comp-macro.png GetLEDIndex2D
Sets the index of a single LED in RAM as a 2D array.
LED Column to change the colour / Range: 0 to (LED Column - 1)
LED Row to change the colour / Range: 0 to (LED Row - 1)
GetLEDIndex3D
Fc9-comp-macro.png GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
Fc9-comp-macro.png Initialise
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the LED ICs in the chain.
OutputHigh
Fc9-comp-macro.png OutputHigh
OutputLow
Fc9-comp-macro.png OutputLow
Refresh
Fc9-comp-macro.png Refresh
Clocks out the current colour data to the LEDs from the values stored in RAM
SetAllLEDColour
Fc9-comp-macro.png SetAllLEDColour
Sets the colour of all the LEDs in RAM
Red Colour Channel
Blue Colour Channel
SetBrightness
Fc9-comp-macro.png SetBrightness
Allows the output colour brightness of the LEDs to be scaled down. For example to save current usage or to reduce brightness in dark environments.
Fc9-f32-icon.png - FLOAT Scaler
Range: 0.0 to 1.0 Default: 1.0, 0 = Off, 0.5 = Half Brightness, 1.0 = Full Brightness
SetBrightnessByte
Fc9-comp-macro.png SetBrightnessByte
Fc9-u8-icon.png - BYTE Scaler
Range: 0 to 255 Default: 255, 0 = Off, 128 = Half Brightness, 255 = Full Brightness
SetLEDColour
Fc9-comp-macro.png SetLEDColour
Red Colour Channel
Blue Colour Channel
ShiftLEDs1D
Fc9-comp-macro.png ShiftLEDs1D
Shifts the LED colours in 1D and wraps
Fc9-u8-icon.png - BYTE Direction
0 = Forwards, 1 = Backwards
Fc9-u8-icon.png - BYTE DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
ShiftLEDs2D
Fc9-comp-macro.png ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
Fc9-s16-icon.png - INT X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
Fc9-s16-icon.png - INT Y
ShiftLEDs3D
Fc9-comp-macro.png ShiftLEDs3D
Fc9-s16-icon.png - INT Z
Fc9-conn-icon.png Controller IC
Fc9-type-16-icon.png LED Controller
Allows the user to select which LED controller IC they are using. The different controller ICs all work the same way but have different timing characteristics.
Fc9-type-16-icon.png Data Order
Configures the order the colour data is clocked out to the LEDs
Fc9-type-15-icon.png Reset Time (uS)
Blanking reset period to reset the LED shift chain and start from the beginning
Fc9-type-15-icon.png T0H (uS)
Logic 0 high time in microseconds
Fc9-type-15-icon.png T0L (uS)
Logic 0 low time in microseconds
Fc9-type-15-icon.png T1H (uS)
Logic 1 high time in microseconds
Fc9-type-15-icon.png T1L (uS)
Logic 1 low time in microseconds
Fc9-conn-icon.png LED Properties
Fc9-type-16-icon.png LED Arrangement
Controls the arrangement of the LEDs on the panel. 1D - Creates a straight line of LEDs 2D - Creates an X by Y Array of LEDs 3D - Creates an X by Y by Z Array of LEDs
Fc9-type-21-icon.png LED Count
Total number of LEDs in the design
Fc9-type-15-icon.png Column Spacing
X Spacing Between LEDs on the Panel
Fc9-type-5-icon.png Data Pin
LED Data Pin - Connected to the Data In pin of the first WS821x IC.
