Component: Object Helper ( Data)
Author MatrixTSL
Version 0.1
Category Data
Object Helper component
Component to help when dealing with Javascript objects.
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Object.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Object.fcsx
Weather Example
Example program showcasing a number of components used together to collect data from a URL using fetch, before processing the data using the object helper and array helper components.
FC6 Icon.png Web Weather Example
GetKeys
Fc9-comp-macro.png GetKeys
Returns a list of the JavaScript object's keys
Fc9-h32-icon.png - HANDLE Object
The JavaSctipt object
GetValue
Fc9-comp-macro.png GetValue
Gets the value for a key in a JavaScript object
The JavaScript object
Fc9-string-icon.png - STRING sKey
The key name
JSONToObject
Fc9-comp-macro.png JSONToObject
Converts a JSON string to a JavaScript object
The JSON string to convert to a JavaScript object
NumberToObject
Fc9-comp-macro.png NumberToObject
Converts a number to a JavaScript object
Fc9-s32-icon.png - LONG Var
The number to convert to a JavaSctipt object
ObjectToFloat
Fc9-comp-macro.png ObjectToFloat
Converts an object to a floating point value
ObjectToInteger
Fc9-comp-macro.png ObjectToInteger
Converts an object to an integer
ObjectToJSON
Fc9-comp-macro.png ObjectToJSON
Converts an object to a JSON string
ObjectToNumber
Fc9-comp-macro.png ObjectToNumber
Converts an object to a number
ObjectToString
Fc9-comp-macro.png ObjectToString
Converts an object to a string
SetValue
Fc9-comp-macro.png SetValue
Sets the value of a key in a JavaScript object. Returns true if the key already exists.
The key name
Fc9-h32-icon.png - HANDLE Value
The value for the key
StringToObject
Fc9-comp-macro.png StringToObject
Converts a string to a JavaScript object
Fc9-string-icon.png - STRING Var
The string to convert to a JavaScript object
