Component: Barometer (BMP180) (Environmental)
(Redirected from Component: ID 38f89887 af35 470e 8c6f c91f3c99e88d)
Version | 1.1 |
Category | Environmental |
Barometer (BMP180) component
Barometric pressure sensor with a I2C bus interface. Pressure range 300 to 1100 hPa. Temperature range -40 to +85 °C.
Please click here to download the component source project: FC_Comp_Source_Pressure_Sensor_BMP180.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Pressure_Sensor_BMP180.fcfx
Altitude
Altitude | |
Calculates the altitude based on difference between actual pressure and the pressure at the sea level P0=1013.25 hPa. | |
- FLOAT | Return |
Forced_Read
Forced_Read | |
- VOID | Return |
I2C_Read_Register
I2C_Read_Register | |
Reads a byte value from a register on the device | |
- BYTE | Address |
- BYTE | Return |
I2C_Write_Register
I2C_Write_Register | |
Writes a byte value to a register on the device | |
- BYTE | Address |
- BYTE | Value |
- VOID | Return |
Initialise | |
Starts up the I2C bus and initialises the pressure sensor ready for use. Returns 1 for a sucessful startup. Returns 0 for a failed startup or no device detected. | |
- BYTE | Return |
ReadPressureFloat
ReadPressureFloat | |
Reads the pressure as a floating point value in Bars. Calls the ReadPressureRaw function and then converts to a meaningful value. | |
- FLOAT | Return |
ReadTemperatureFloat
Reset
Reset | |
Resets the device | |
- VOID | Return |
