Component: Potentiometer (Slider) (Analog Input)
Category Analog Input
Potentiometer (Slider) component
Please click here to download the component source project: FC_Comp_Source_Pot_Slider_Gdi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Pot_Slider_Gdi.fcfx
GetAverageByte
Fc9-comp-macro.png GetAverageByte
Read the ADC as a byte
Fc9-u8-icon.png - BYTE NumSamples
Fc9-u8-icon.png - BYTE DelayUs
GetAverageInt
Fc9-comp-macro.png GetAverageInt
Read the ADC at full bit depth
GetByte
Fc9-comp-macro.png GetByte
GetInt
Fc9-comp-macro.png GetInt
GetString
Fc9-comp-macro.png GetString
Reads the ADC as a direct voltage
GetVoltage
Fc9-comp-macro.png GetVoltage
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
Fc9-type-7-icon.png Retain Value
Fc9-type-10-icon.png Modified connection
Fc9-conn-icon.png Appearance
Fc9-type-7-icon.png Show Connection Label
Fc9-type-7-icon.png Show Pin Value
Fc9-type-2-icon.png LabelColour
Fc9-type-12-icon.png Colour Style
Fc9-type-12-icon.png Style
Fc9-conn-icon.png Simulation
