Component: Temp / Humidity (SHT31) (Environmental)
(Redirected from Component: ID 4475d8e8 4f60 48be 8a27 e91d85fbabae)
Version | 2.0 |
Category | Environmental |
Temp / Humidity (SHT31) component
Humidity and temperature sensor using an SHT31 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
Please click here to download the component source project: FC_Comp_Source_Humidity_SHT31.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Humidity_SHT31.fcfx
GetHumidityData
GetHumidityData | |
Returns the raw register pair value | |
- UINT | Return |
GetHumidityInt
GetHumidityInt | |
returns the relative Humidity reading as an integer value | |
- INT | Return |
GetHumidityReal
GetHumidityReal | |
returns the Humidity reading as a float value | |
- FLOAT | Return |
GetTemperatureData
GetTemperatureData | |
- UINT | Return |
GetTemperatureInt
GetTemperatureInt | |
Return temperature reading as an integer value in degrees C | |
- INT | Return |
GetTemperatureReal
GetTemperatureReal | |
Return temperature reading as a float value in degrees C | |
- FLOAT | Return |
