Component: Starburst Display (Segment)
Version 1.4
Category Segment
Starburst Display component
Starburst 14 or 16 segment display modelled after a standard 14mm high unit. LED colour can be changed in properties.
Please click here to download the component source project: FC_Comp_Source_LED_Starburst_Single_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Starburst_Single_2dgi.fcfx
Example program showing how to use the starburst display component to display alphanumeric ASCII characters. FC6 Icon.png Starburst Test Example program showing how to multiplex between several starburst displays. Takes an ADC reading and displays the reading in decimal using 4 starburst display components. FC6 Icon.png Starburst Multi Example program showing how to multiplex between several starburst displays. Takes an ADC reading and displays the reading in hexadecimal using 4 starburst display components. FC6 Icon.png Starburst Multi Hex StarBurst.jpg
ClearSegments
Fc9-comp-macro.png ClearSegments
This funtion clears all the individual segments including the decimal point segment. In simulation this sets the colours to the default BGColor component variable.
ShowCharacter
Fc9-comp-macro.png ShowCharacter
Allows certain pre-programmed characters to be displayed. 0-9, A-Z, $, [, ], +, -, \, /, *, _, {, }, .
0-9 or A-Z
Fc9-u8-icon.png - BYTE DecimalPoint
0=Off, 1=On
ShowSegments
Fc9-comp-macro.png ShowSegments
Creates the supplied digit on the 7 segment display. Macro takes the digit to display and a boolean representing whether to display the decimal point segment or not.
Fc9-u8-icon.png - BYTE Segments0
Segment bits 0=Off 1=On : F/E/D2/D/C/B/A2/A
Fc9-u8-icon.png - BYTE Segments1
Segment bits 0=Off 1=On : M/L/K/J/I/H/G2/G1
Segment bits 0=Off 1=On : DecimalPoint
Fc9-type-16-icon.png Display Segments
Controls the starburst display type and number of segments available.
Fc9-type-16-icon.png Display Type
Set this property to match your hardware device. Common Anode: Common Pin High, Segment Pin Low = LED On Common Cathode: Common Pin Low, Segment Pin High = LED On
Fc9-type-16-icon.png Common Mode
Controls if the display will be multiplexed or always on. Multplexed uses the common pin to switch a individual display on or off allowing for multiple displays. Always on removes the common pin assuming you are only using a single starburst display.
Fc9-type-7-icon.png Show Seg Labels
Show the identifier lables of the segments overlayed over the component.
Fc9-type-5-icon.png Pin A
Pin connected to the 'A' segment of the display.
Fc9-type-5-icon.png Pin B
Pin connected to the 'B' segment of the display.
Fc9-type-5-icon.png Pin C
Pin connected to the 'C' segment of the display.
Fc9-type-5-icon.png Pin D
Pin connected to the 'D' segment of the display.
Fc9-type-5-icon.png Pin E
Pin connected to the 'E' segment of the display.
Fc9-type-5-icon.png Pin F
Pin connected to the 'F' segment of the display.
Fc9-type-5-icon.png Pin G1
Pin connected to the 'G1' segment of the display.
Fc9-type-5-icon.png Pin G2
Pin connected to the 'G2' segment of the display.
Fc9-type-5-icon.png Pin H
Pin connected to the 'H' segment of the display.
Fc9-type-5-icon.png Pin I
Pin connected to the 'I' segment of the display.
Fc9-type-5-icon.png Pin J
Pin connected to the 'J' segment of the display.
Fc9-type-5-icon.png Pin K
Pin connected to the 'K' segment of the display.
Fc9-type-5-icon.png Pin L
Pin connected to the 'L' segment of the display.
Fc9-type-5-icon.png Pin M
Pin connected to the 'M' segment of the display.
Fc9-type-5-icon.png Pin DP
Pin connected to the decimal point segment of the display.
Fc9-type-5-icon.png Common
Pin connection to the 'common' pin of the display - to allow enable/disable of the whole display.
Fc9-conn-icon.png Colors
Fc9-type-1-icon.png LED Color
Color when an LED is turned on. When turned off, will use a much darker shade of the same hue.
Fc9-type-1-icon.png Bezel Color
Color of the plastic package housing the LEDs
Fc9-type-1-icon.png Label Color
Color of the optional segment name labels.
