Component: Oven Simulation (Scenarios)
(Redirected from Component: ID 6d87ff3b ffd8 4720 92cc 363be1e8be6e)
Version | 1.0 |
Category | Scenarios |
Oven Simulation component
Component designed to provide a simple simulation of a real world oven. Can be used with a simple controller such as on/off to create a standard kitchen oven. Can be used with a more complex controller such as PID to create a high accuracy temperature oven e.g. a SMD reflow oven.
Please click here to download the component source project: FC_Comp_Source_OvenSim.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_OvenSim.fcfx
An example showing 4 x 7seg LED's counting up using timer 2 interrupt
OutputAnalogue
OutputAnalogue | |
Switch the oven element partially on, probably using something like PWM connected via a TRIAC or FET. | |
- FLOAT | Value |
Range: 0.0 (OFF) to 1.0 (ON) | |
- VOID | Return |
OutputOff
OutputOff | |
Switch the oven element off, probably using something like a relay. | |
- VOID | Return |
OutputOn
OutputOn | |
Switch the oven element on, probably using something like a relay. | |
- VOID | Return |
ReadElementTemperature
ReadElementTemperature | |
Reads the temperature of the heater element | |
- FLOAT | Return |
ReadOvenTemperature
ReadOvenTemperature | |
Reads the air temperature inside the oven | |
- FLOAT | Return |
ReadPowerUsage
ReadPowerUsage | |
Reads the ovens power consumption in KWh. | |
- FLOAT | Return |
ResetPowerUsage
ResetPowerUsage | |
Resets the recorded power usage to 0KWh | |
- VOID | Return |
