Component: ADC Template 2D (Analog Input)
(Redirected from Component: ID 9b845489 48f5 4fa5 aace 2c97efdcede3)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.3 |
Category | Analog Input |
ADC Template 2D component
Base ADC component with no graphical interface. Contains all of the embedded side component calls to provide an ADC interface suitable for wrapping with a new ADC style component.
Please click here to download the component source project: FC_Comp_Source_adc_Base_2dgdi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_adc_Base_2dgdi.fcfx
GetAverageByte
GetAverageByte | |
Function call to read the ADC as a byte average sample over time | |
- BYTE | NumSamples |
- BYTE | DelayUs |
Number of micro seconds in between taking each sample | |
- BYTE | Return |
GetAverageInt
GetAverageInt | |
Function call to read the ADC as a full width average sample over time | |
- BYTE | DelayUs |
- UINT | Return |
GetByte
GetByte | |
Blocking call to read the ADC as a byte | |
- BYTE | Return |
GetInt
GetInt | |
Blocking call to read the ADC at full bit depth | |
- UINT | Return |
GetSampleBits
GetSampleBits | |
Gets the number of bits per sample | |
- BYTE | Return |
GetSpeedFilter
GetSpeedFilter | |
Gets the Conversion speed filter string Use in Component.Property.SetFilter() | |
- STRING | Return |
GetString
GetString | |
Reads the ADC as a direct voltage and returns as a string | |
- STRING | Return |
GetVoltage
GetVoltage | |
Reads the ADC as a direct voltage | |
- FLOAT | Return |
RawAverageByte
RawAverageInt
RawAverageInt | |
Background call to read the ADC as a full width average sample over time Call Enable() before this | |
- BYTE | DelayUs |
- INT | Return |
RawDisable
RawDisable | |
Disables the previously enabled ADC channel and converts back to digital mode. | |
- VOID | Return |
RawEnable
RawEnable | |
Enables and configures the ADC channel to be an analogue input. Only one ADC channel can be enabled at a time. Any RAW functions will reference the last enabled channel only. | |
- VOID | Return |
RawSampleByte
RawSampleByte | |
Background call to read the ADC as a byte Call Enable() before this | |
- BYTE | Return |
RawSampleInt
RawSampleInt | |
Background call to read the ADC at full bit depth Call Enable() first | |
- UINT | Return |
SetChannel
SetChannel | |
Sets the channel ID for the component | |
- INT | ChannelId |
Chaannel starting at 0, -1 is unconnected | |
- VOID | Return |
SetProperties
