Component: Array Helper ( Data)
Author MatrixTSL
Version 0.1
Category Data
Array Helper component
Component designed to allow manipulation of Javascript arrays.
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Array.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Array.fcsx
Weather Example
Example program showcasing a number of components used together to collect data from a URL using fetch, before processing the data using the object helper and array helper components.
FC6 Icon.png Web Weather Example
ArrayAddValue
Fc9-comp-macro.png ArrayAddValue
Adds an element to a JavaScript array object. Returns the new size of the array.
Fc9-h32-icon.png - HANDLE Object
The JavaScript object
Fc9-u32-icon.png - ULONG Index
The element index
Fc9-h32-icon.png - HANDLE Element
The new element to add to the array
ArrayGetLength
Fc9-comp-macro.png ArrayGetLength
Gets the length of a JavaScript array object
ArrayGetValue
Fc9-comp-macro.png ArrayGetValue
Gets the value of an element in a JavaScript array object
The element index
ArrayIndexOf
Fc9-comp-macro.png ArrayIndexOf
Gets the index of a value within a JavaScript array object
Fc9-h32-icon.png - HANDLE Value
The value to look for within the array
Fc9-s16-icon.png - INT Start
The index to start the search (use negative numbers to search backwards)
ArrayParse
Fc9-comp-macro.png ArrayParse
Parse a JavaScript array object by calling the macro for each element in the array.
ArrayRemoveValues
Fc9-comp-macro.png ArrayRemoveValues
Removes elements from a JavaScript array object. Returns the new size of the array.
The element index
Fc9-u32-icon.png - ULONG Count
The number of values to remove from the array
ArraySetValue
Fc9-comp-macro.png ArraySetValue
Sets the value of an element in a JavaScript array object
The element index
The new value for the array element
IsArray
Fc9-comp-macro.png IsArray
Returns true if the JavaScript object is an array
Fc9-type-24-icon.png ParseArray macro
Allows an easy way to parse an array element by element
