Component: STM32 Timer (Timing)
Version 1.1
Category Timing
STM32 Timer component
Allows you to measure the passage of time via the use of the STM hardware timer. Works like a stopwatch with macros to start, stop and reset the timer counter. Returns time as integer Seconds, Milliseconds and also Floating Point and String.
Please click here to download the component source project: FC_Comp_Source_TimerComponentSTM32.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerComponentSTM32.fcfx
GetCountMilliseconds
Fc9-comp-macro.png GetCountMilliseconds
Returns the count value as a number of milliseconds
Fc9-u32-icon.png - ULONG Return
GetCountReal
Fc9-comp-macro.png GetCountReal
Returns the count value as a floating point value in seconds.
GetCountSeconds
Fc9-comp-macro.png GetCountSeconds
Returns the count value as a number of whole seconds, rounded down to the nearest second
GetCountString
Fc9-comp-macro.png GetCountString
Returns the count value as a floating point string in seconds.
Fc9-u8-icon.png - BYTE Precision
Number of decimal places to display in string
GetRawCount
Fc9-comp-macro.png GetRawCount
Returns the number of milliseconds elapsed since the timer was started.
ResetCounter
Fc9-comp-macro.png ResetCounter
StartCounter
Fc9-comp-macro.png StartCounter
Starts the timer counting.
Fc9-bool-icon.png - BOOL ResetCounters
Range: 0-1 where 0=Do Not Reset and 1=Reset
StopCounter
Fc9-comp-macro.png StopCounter
Stops the timer counting.
Fc9-conn-icon.png Simulation
Fc9-type-21-icon.png Timer Delay (ms)
Number of milliseconds between timer events which increment the simulated timer counter variable. 10ms will yield the highest resolution. Values less than this will likely just increase the error and making the timer run slow. Higher delays will yield greater accuracy.
Fc9-type-21-icon.png Decimal Points
