Component: Digital Potentiometer (MCP41XXX / MCP42XXX) (Analog Output)
Category Analog Output
Digital Potentiometer (MCP41XXX / MCP42XXX) component
The MCP41XXX and MCP42XXX device range supports up to 2 digital potentiometer outputs. With 256 possible output resistance values for each channel.
Please click here to download the component source project: FC_Comp_Source_MCP41xxx_42xxx_Digital_Pot.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MCP41xxx_42xxx_Digital_Pot.fcfx
Fc9-comp-macro.png Initialise
Startup the SPI peripheral ready for communications.
SetWiper
Fc9-comp-macro.png SetWiper
Sets the value of a single wiper
Fc9-u8-icon.png - BYTE Index
Range: 0-2 / 0=CH0, 1=CH1, 2=CH0 AND CH1
Fc9-u8-icon.png - BYTE Value
256 Taps Range: 0-255
Fc9-conn-icon.png SPI Properties
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-16-icon.png MOSI Remap Pin
Fc9-type-5-icon.png MISO
Fc9-type-16-icon.png MISO Remap Pin
Fc9-type-5-icon.png CLK
Fc9-type-16-icon.png CLK Remap Pin
Fc9-type-5-icon.png CS / SS
Fc9-conn-icon.png Device Properties
Fc9-type-16-icon.png Number of Outputs
Fc9-type-16-icon.png Number of Taps
Fc9-conn-icon.png Simulation
